required power sequence and schematic of GA-H61M-S2P
  • sanehdeep2012
    • Oct 2013
    • 139
    • india
    Dear Bad caps Team and friends,
    thanks in advance,
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: required power sequence and schematic of GA-H61M-S2P
    Here you go:
    • sanehdeep2012
      • Oct 2013
      • 139
      • india
      Thanks meritosari for your help.
      sorry for delay reply , i was not well.
      • sanehdeep2012
        • Oct 2013
        • 139
        • india
        hi masters
        I have need the power sequence of the Gigabyte H61 Motherboards
        GA-H61M-WW
        GA-H61M-S1
        GA-H61M-S2
        AND SO ON
        KUNDLY HELP Power sequence for any h61 gigabyte mother boards
        I need all what ever any body have Please share.
        thanks master hope some body will help on this regards
        • feskawy
          • Jun 2018
          • egypt
          • godfrey7
            • Apr 2020
            • 12
            • india
            Thanks for power sequence
            • totto210
              • Apr 2021
              • 48
              • chaco
              hi, the power sequence here is simple :
              in general for all gigabyte h61 basics
              -go to page 13
              - you can see the 5VSB line entry and runs q62 this mosfet regulates the 3.3vsb for pch and calls it 3vdual_pch (u can see too free line for this in VCCDSW 3_3 in pch) many others supplied by this line (lan, usb etc in stand by mode)
              - now go to page 20 fp intel you can see 3vdual_pch is in the + line of the pw+
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • Andreas_de
                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                by Andreas_de
                Hello!
                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                04-12-2025, 10:38 AM
              • claws77
                lenovo flex 5 14itl05 power sequence issue
                by claws77
                hi guys, my motherboard will not start no matter what
                when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                but rest nothing happens no sign of life.
                this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                i have no knowledge of motherboards ....
                10-20-2024, 02:48 PM
