HP Touchsmart 310 bios
  • nixi22
    • May 2016
    • 44
    • Croatia
    Does anyone have main bios dump for this machine it's almost impossible to find anything online tnx.
    HP Touchsmart 310-1125ad
    DA0NZ2MB6F0 REV f
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP Touchsmart 310 bios
    backup your bios
    Im Back... sort of...
    • nixi22
      • May 2016
      • 44
      • Croatia
      Thank you ala_borbe coud not back up old bios cuz of corrupted chip with new chip and your dump machine works tnx again
      • Mazorca
        • Jan 2017
        • 463
        I tried given BIOS by ala_borbe but my original bios size does not match (1024KB), with original, pc turns on, fan spins but no video, unlit screen. With this bios(2048KB), pc won't even start, presssing on button does nothing.
        • Mazorca
          • Jan 2017
          • 463
          I'm going to try another BIOS chip and reprogram it.
          • Mazorca
            • Jan 2017
            • 463
            Motherboard is now working after changing Bios chip for another one, using old bin file, 1024KB. For some reason, the given 2048KB file would not work, and after changing chips and resoldering, I didn't want to do further work.
            I thank the community for helping us with Bios bins.
              • 21841
              On this model the bios is 2MB,the EC is 1MB .
              • Mazorca
                • Jan 2017
                • 463
                So I was messing with the wrong chip? Glad to know, learning experience. Well, yesterday customer brought the AIO back, would briefly turn on again, then image would turn off. I did hear the Windows start-up music, so I knew data was going in, just no backlight. This AIO has an inverter, checked out good, but I smelled burning plastic, turns out there was a short on the wires going into the top lamp. PC case shows signs of a rough opening by a prior tech, metal screwdriver perhaps, probably he inserted it too far.
                So it's fixed now, I just resoldered the wires back into the lamp. NOT an easy job to get into.
                Lesson learned, I need to follow my nose more. Thanks to SMDFlea too.
                • hussaka
                  • Jan 2015
                  • 154
                  • italy
                  thank you
                  • hussaka
                    • Jan 2015
                    • 154
                    • italy
                    thank you so much
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      by haitham sharabati
                      Hello engineers 😀,
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      💀 Problem:😅
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
