problem in format bios GA-H61M-S1 REV 2.1
  • kadi144
    • Aug 2015
    • 690
    • algerie
    HI......ALL
    i need a bios format .bin for GYGABYTE GA-H61M-S1 REV 2.1o
    OR someone can change for me the extension to .bin
    it s from hp site .10b format
    thanks for all helping
    • 31247
    Re: problem in format bios
    .10b is a binfile, just rename the extension to .bin
    • mjavicop
      • May 2022
      • 6
      • quito
      Re: problem in format bios GA-H61M-S1 REV 2.1
      WORKS ga-h61m s1 rev2.1 even accepts NVMe WITH pci ADAPTER
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • trouble55
        NEC VersaPro PC-VRT42FBFR22B BIOS problem
        by trouble55
        Hi All,
        [Mother board model]
        V-VE212(U3E1)
        [Serial number]
        24000135PA
        [BIOS chip model]
        Macronix MX77L12850F
        I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
        I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
        I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
        09-19-2024, 01:24 AM
      • c.daniel
        Lenovo V310-15IKB weird bios problem...
        by c.daniel
        Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
        sn LR09493E
        MB DAOLV6MB6F0 REV. F
        The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
        Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
        Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
        08-22-2025, 05:39 AM
