Hp elite tower 800 G9 desktop pc bios password
  • danish8717
    • Dec 2021
    • 27
    • united arab emirates
    Please help unlock this bios
    Model : Hp elite tower 800 G9 desktop pc
    serial : 4CE327C6TQ
    Product number : 6Z8F1EC#ARE
  • Ponto da Manutenção
    • May 2024
    • 99
    • Brasil
    Check if it solved...
    • danish8717
      • Dec 2021
      • 27
      Still password
        • May 2024
        • 99
        • Brasil
        check..
        • danish8717
          • Dec 2021
          • 27
          i already tried the changes you made .but it doesn't make any progress 😞 removing user cred part, removing active nvram part ( in ec ) , injecting another nvram region in main bios , but no luck
          appreciating your efforts ...🫡
          • shiriff47
            • May 2018
            • 45
            • Algeria
            hello , i need help to unlock HP Elite Tower 800 G9
            motherboard : SCRABBLE REV : B M11 FMB-2202
            Serial Number: CZC315715W
              • May 2024
              • 99
              • Brasil
              Enter the BIOS Setup by pressing F10 during first boot. You will be asked if you would like to access the BIOS as a GUEST. Click YES and on the first screen you'll see the option to set the new BIOS Admin Password.
              • shiriff47
                • May 2018
                • 45
                • Algeria
                THANK YOU BUT IT NOT WORKING STILL LOCKED
                  • May 2024
                  • 99
                  • Brasil
                  check
                  • shiriff47
                    • May 2018
                    • 45
                    • Algeria
                    check
                    Thanks but it still locked
                    • danito
                      • Jun 2016
                      • 1091
                      try
                      • shiriff47
                        • May 2018
                        • 45
                        • Algeria
                        Originally posted by danito
                        try
                        Thank you but it didn't work
                        everytime it shows me on the first boot this msg : the bios hasrecovered its identity data from the embedded controller due to data mismatch
                        i think i need to get a fresh EC with low version to be able to downgrade the bios and patch it.
                        i tried to extract bios from update but i can't figured out how to downgrade the EC from update
                        is the anyone who can provide me a fresh EC
                        this is my original both BIOS+EC after my attempt to downgrade
                        • adamgouadma
                          • Jul 2017
                          • 199
                          • setif
                          please need help to remove bios password
                          SN/ CZC3157163
                          Thanks in advance...
                          • shiriff47
                            • May 2018
                            • 45
                            • Algeria
                            IS there any solution for this model??
                            • volinakis
                              HP Elite Mini 600 G9 Desktop PC Bios Password
                              by volinakis
                              Hi, I need help to remove bios password please.
                              Name: HP Elite Mini 600 G9 Desktop PC
                              S/N: 8CC4131WJ8
                              Prod Id: 4C5J7AV
                              I did usual modifications to enter in MPM mode but with modifications it restarts several times then when it boots it appears message: "Bios Identity Data Recovered The BIOS has recovered its identity data from the Embedded Controller due to data mismatch" and did not enter in MPM mode.
                              I attach main and EC backups, maybe Badcaps Masters can help me, thank you in advance.
                              post moved......
                              09-10-2024, 12:34 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • traxformania
                              TONGFANG "GM7TG7P" Bios Password Problem?
                              by traxformania
                              I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                              But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                              I'm trying to reset my bios without success.
                              I tried :
                              -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                              11-15-2023, 07:32 AM
                            • tlindi
                              Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                              by tlindi
                              Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                              >Read BIOS guides, methods, resources and tools
                              Ack
                              >Try the method at BIOS guides, methods, resources and tools before requesting help
                              Ack
                              >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                              python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                              01-30-2025, 04:26 AM
                            • Nopslide
                              HP Omen 15-dh0052nf power-on & bios password
                              by Nopslide
                              Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                              My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                              Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                              04-01-2024, 04:27 PM
