please repair this bios dump corrupted
Bios Bin Asus Prime H510M-D
by DynaxSCHi,
Usually on ASUS boards it worked...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by reset1986Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks...
- Loading...
