DI2 ENTRY OPTI3 INS VOS CM(NU) bios please!!!
  • FalconPunch
    Surface Pro X 1876 Bios corrupted
    by FalconPunch
    Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
    Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
    08-09-2025, 03:56 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • Talonts
    Dell Latitude 7290 enable touchscreen entry in BIOS?
    by Talonts
    For those that have worked through the 7290 BIOS in the past, do you happen to know if there is a switch in it to enable a touchscreen entry in the BIOS setup?
    The 7290, 7390, and 7490 all use the same BIOS, and the 7390 has an FHD touchscreen as one of its' options. It turns out it can be installed in a 7290 BUT since the BIOS doesn't have the entry to turn it on, it just becomes an FHD upgrade to the 7290.
    I was hoping if any of you that had worked on the BIOS in the past would know if either the touchscreen settings could be turned on in the 7290, or the BIOS could...
    06-24-2025, 11:27 PM
  • TylerHyde21
    Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
    by TylerHyde21
    Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
    I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
    I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
    This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
    06-29-2024, 10:38 AM
  • Loli Popu
    DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
    by Loli Popu
    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
    12-13-2024, 08:29 AM
