MSI B360A-PRO - BIOS BIN FILE PLS?
  • servicepcpascani@gmail.co
    • Oct 2022
    • 29
    • romania
    MSI B360A-PRO
    CAN SOMEONE HELP ME WITH THE BIOS FILE IN .BIN FORMAT? THE BIOS UPDATE IN WINDOWS WAS BLOCKED AND IT DOESN'T SHOW UP AT ALL AT STARTUP.
    I AM ATTACHING THE ALTERED FILE BELOW, READ FROM THE BOARD​
    • 22084
    Get the bios from MSI support - https://www.msi.com/Motherboard/B360-A-PRO/support .Rename the file extension from whatever it is to .bin ,for example E7B22IMS.2E0 to E7B22IMS.bin
      • Oct 2022
      • 29
      • romania
      I had a hunch that this is how it works but I didn't want to risk it. It worked, first I tried an older version but it didn't work, then I chose an intermediate version, e.g. 280 and it works. thanks
      for anyone who needs it, I'll upload it below:​
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • maanee11
        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
        by maanee11
        Hello Everyone,
        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
        In the website, you can only see specs etc.
        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
        11-08-2025, 04:08 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
