Hello everyone, I need help and schematic and boardviuw of ASUS PRIME A320M-K boards. Thank you for your help.
ASUS PRIME A320M-K schematic and boardview
This topic has been answered.
Answer selected by StaKen at 12-21-2024, 05:07 AM.
there you go.Attached Files- Selected Answer
by GeomihCouldn't find this particular board on badcaps so here it is for safe keeping...
Channel: Schematics and Boardviews
by DynaxSCHi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent... -
by RotVikHello, I need a little help
I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...-
by taurtntneed ASUS Prime Z490-P boardview diagram
Hi, I have an ASUS Prime Z490-P motherboard, it doesn't start and I need the boardview diagram, if anyone can help me-
01-24-2025, 10:26 AM -
by lezsimplyHello Everyone and Good Day,
I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's... - Loading...
