Bios needed NUC8I7HVK
  • jackpiratjackpirat
    • Jun 2021
    • 13
    Hello.
    Bios needed for intel nuc NUC8I7HVK
    Product cod : BOXNUC8I7HVK2
    SN : bthn00400bf
    S/A : j71485-602
    Dump attached
    • Jun 2021
    • 13
    Any help ?
    Thank you.
      • Jun 2021
      • 13
      Tried something but after almost 60 sec will display an image .
      Any solutions ?
        • 21849
        Any solutions ?
        Yes, clean the ME firmware
          • Jun 2021
          • 13
          Don't know how...
            • Jun 2021
            • 13
            Tried some youtube instructions , but no luck.
              • 21849
              Don't know how...
              ok ,try this one
                • Jun 2021
                • 13
                I tried the one you maked , the problem i think is not working at all is because this one is the first dump , the one with no display. Still no display with the me_clean.
                Can you clean_me the one i tried and has image but has 60 sec delay ?
                Is attached .
                Thank you very much.
                  • Jun 2021
                  • 13
                  Solved.
                  I managed to take the me_region from your bios and put it in the one with delay. made the new bios file.
                  Everything works.
                  Thank you.
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • TacticalFahrrad
                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                    by TacticalFahrrad
                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                    06-30-2025, 04:09 AM
                  • James Maxwell
                    HP DM1-4000er Bios Dump needed
                    by James Maxwell
                    I badly need bios dump for HP DM1-4000er,
                    Model: HP DM1-4000er
                    Motherboard: DA0NM9MB6D0 REV.D
                    Product: QJ490EA#ACB
                    Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                    10-28-2024, 05:38 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • rednix01
                    Nuc7i5BNH Bios Dump Needed
                    by rednix01
                    I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
                    Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
                    I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...
                    06-19-2025, 06:37 PM
