MS-7D25_BIOS
  • DynaxSC
    • Apr 2021
    • 453
    • Poland
    MS-7D25_BIOS
    Bios repair request. Attached a zip file with both files.
  • Ponto da Manutenção
    • May 2024
    • 97
    • Brasil
    I am extremely pleased to be able to try to help you!
    I am sending the extracted and repaired file.
    • joshAU
      BIOS file for N550JK (original dump attached)
      by joshAU
      Hi all.
      I'm looking for a BIOS file for an Asus N550JK.
      I have a Asus R552J, which I believe is identical to the Asus N550JK.
      I downloaded the latest BIOS (210) for the R552.
      It is named N550JKAS.210.
      The BIOS file is however only 6mb in size.
      I've read the chip with a CH341A programmer and verified the file.
      That file is actually 8mb in size.
      I'm wanting to remove the BIOS password from this unit.
      It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
      08-09-2022, 08:06 PM
    • wishes2022
      How to extract attached BIOS file.
      by wishes2022
      Hi Guys ,
      How to extract attached BIOS file. please help。
      Thanks in advance ! from china
      12-23-2023, 05:11 PM
    • Forest79
      by Forest79
      However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
      07-23-2023, 07:39 AM
    • EbrahimSiami
      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
      by EbrahimSiami
      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
      **What I have tried so far:**
      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
      07-02-2025, 02:31 PM
    • EazyBone
      Hisense 55H8F Emmc programming help
      by EazyBone
      I am extremely new to programming and dipping into this. I picked up a XGECU T48 Programmer and have the correct socket for EMMC.
      I took the EMMC off a working main board with no problems and threw it into the programmer. I click analysis IC and it gives me a report (attached) of the current EMMC. Model H26M41204HPR
      1) I manually found this chip(above model number) in the select IC section of the XGPRO 12.xx programmer software and it had a option for 4 bit and 1 bit. I chose 4... is this correct?
      2) In the options section point number 2 operation says "30...
      06-11-2024, 06:03 PM
