MS-7D25_BIOS
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • joshAU
    BIOS file for N550JK (original dump attached)
    by joshAU
    Hi all.
    I'm looking for a BIOS file for an Asus N550JK.
    I have a Asus R552J, which I believe is identical to the Asus N550JK.
    I downloaded the latest BIOS (210) for the R552.
    It is named N550JKAS.210.
    The BIOS file is however only 6mb in size.
    I've read the chip with a CH341A programmer and verified the file.
    That file is actually 8mb in size.
    I'm wanting to remove the BIOS password from this unit.
    It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
    08-09-2022, 08:06 PM
  • wishes2022
    How to extract attached BIOS file.
    by wishes2022
    Hi Guys ,
    How to extract attached BIOS file. please help。
    Thanks in advance ! from china
    12-23-2023, 05:11 PM
  • Forest79
    by Forest79
    07-23-2023, 07:39 AM
