ASUS B450M-PLUS GAMING rev.1.03 BIOS
This topic has been answered.
  • unimatrix93
    • Oct 2021
    • 345
    • Magyarország
    Dear community, I would like to ask for a working BIOS dump for this board. Symptom: No display with new CPU (R5 3600), can't access old CPU for tradition bios update.
    Here is the original bios I saved from the ISP IC:
    Thank you!
  • Answer selected by unimatrix93 at 09-17-2024, 03:42 AM.
    unimatrix93
    • Oct 2021
    • 345
    • Magyarország
    Originally posted by SoporteNetFe
    Maybe broken pin on processor? it's very common...
    The pins are intact on the CPU, but I managed to solve the problem by going into the bios settings and changing the PCIE1 mode from Auto to 8x8x.
    This way the GPu do displays corretcly from the first PCIE slot.
    • SoporteNetFe
      • Aug 2021
      • 116
      • Argentina
      This dump is 4401 version. Maybe you have problem with your graphics card, Ryzen 5 3600 dont have integrated graphics.
      Anyway, you can download last version 4604 and extract binary with UEFI Tool:
      https://dlcdnets.asus.com/pub/ASUS/m...-ASUS-4604.zip
      • unimatrix93
        • Oct 2021
        • 345
        • Magyarország
        Can you elaborate more on the procedure please?
        Also, If it wont help:
        What else can produce this problem?
        The system posted and showed display with the same config but with a R3 1200.
        Thank you!
        • SoporteNetFe
          • Aug 2021
          • 116
          • Argentina
          Use UEFITool. https://github.com/LongSoft/UEFITool/releases Open CAP file with UEFITool , select: Action -> Capsule -> Extract body . By default it will name as a *.rom file, you can rename it to *.bin if you like, its the same thing. ( thanks to SMDFlea​ )
          • unimatrix93
            • Oct 2021
            • 345
            • Magyarország
            Use UEFITool. https://github.com/LongSoft/UEFITool/releases Open CAP file with UEFITool , select: Action -> Capsule -> Extract body . By default it will name as a *.rom file, you can rename it to *.bin if you like, its the same thing. ( thanks to SMDFlea )
            I reflashed the dump on the IC but still no display on screen.
            I have an another GPU with a HDMI cable, I will try it.
            UPDATE:
            Turns out it does post and shows display when I install the GPU to the second PCI slot.
            What could be the issue with the first PCI slot?
            I inspected the soldering on it under microscope, looks okay.
            • SoporteNetFe
              • Aug 2021
              • 116
              • Argentina
              • unimatrix93
                • Oct 2021
                • 345
                • Magyarország
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • smallvhin
                  ASUS B150 PRO GAMING AURA help bios updating
                  by smallvhin
                  Master help to fix my bios stock in "bios is updating" I already update my bios to first release and latest but no luck.
                  more thanks
                  bios file
                  ec file...
                  07-14-2025, 10:51 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                  ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook Specification for Upgrade or Repair
                  This specification for the ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GD-EN1324-GAMING boardview and FX504GD-EN1324-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 09:01 AM
