MSI Pro 24X 10M - Need Bios (bin file) please help !!
  • foo007
    • Aug 2024
    • 12
    • Singapore
    Hello Everyone. I need bios file. Please help.
    Model: MSI Pro 24X 10M
    Motherboard: MS-AEC21 Rev 1.0
    CPU: Intel Pentium 6405u
    Bios chip: (MX25L12872F)
    Problems- turn on power only got screen backlight on few second will auto off/on repeat issue. no display input.
    my english is not good hope can understand. πŸ™ Thanks
ID:	3338392 Click image for larger version
    • 21841
    Post the PC serial number and your bios backups https://www.badcaps.net/forum/troubl...before-posting
    • foo007
      • Aug 2024
      • 12
      • Singapore
      Wow thanks for the quick response πŸ™πŸ˜ƒ appreciate it for help.
      My own device bios was corrupted. So i do bios backup on my friend PC is exactly the same model and motherboard.
      my own device S/N: MSAEC2K3S0103001
      • hoaca388
        Badcaps
        • Jan 2022
        • 12322
        PRO 24X 10M
        ​https://www.badcaps.net/donate
        • foo007
          • Aug 2024
          • 12
          • Singapore
          Originally posted by hoaca388
          PRO 24X 10M
          Thank for help. πŸ™
          I have try flash you bios file. But still not work get different problems~ (just only have power), no display, no auto on/off, no screen backlight. 😒
          • hoaca388
            Badcaps
            • Jan 2022
            • 12322
            Chech hardware
            • foo007
              • Aug 2024
              • 12
              • Singapore
              Chech hardware
              Actually my own device last time is fine. because of last time I update bios download from MSI official website. after i update suddenly blank screen was corrupted. is was by my mistake.
              So my hardware it was ok. 😐
              https://my.msi.com/All-in-One-PC/PRO-24X-10M/support
              • hoaca388
                Badcaps
                • Jan 2022
                • 12322
                I also download from MSI. https://www.msi.com/All-in-One-PC/PRO-24X-10M/support
                Just change the extension to .bin.
                • foo007
                  • Aug 2024
                  • 12
                  • Singapore
                  have try still not working... 😐 no display input
                  also i want know if using NeoProgrammer flash need to set Unprotect and SREG ?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12322
                    I don't know. i not use CH341A.
                      • 21841
                      No, don`t mess with any settings,leave it as is,it should program without any problems.
                      • foo007
                        • Aug 2024
                        • 12
                        • Singapore
                        may i know what flash bios tool you using ? πŸ™
                        • foo007
                          • Aug 2024
                          • 12
                          • Singapore
                          my CPU: Intel Pentium 6405u
                          Nuvoton NCT5567D-M
                          OMG.. because of last time my friend help me to flash bios have Accidentally press unprotect already... So what can i do now Need to edit SREG ?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12322
                            SFLY SP20P
                            https://www.sflytech.com/
                            • rogfanther
                              • Jul 2006
                              • 458
                              • Brazil
                              If your friendΒ΄s machine is the same, try writing the backup of his bios to your , to see if it works.
                              • foo007
                                • Aug 2024
                                • 12
                                • Singapore
                                have try it. Still not work.😐
                                Here is my friend bios backup. πŸ‘‡
                                • to5it0
                                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                  by to5it0
                                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                  I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                  This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                  I have opened the laptop and identified the main BIOS chip...
                                  10-24-2025, 01:35 AM
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
                                • m1ch43lzm
                                  Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                  by m1ch43lzm
                                  Hi everyone
                                  I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                  Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                  Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                  There's also an extra OTP Secu.R...
                                  09-06-2025, 05:47 PM
                                • Forest79
                                  by Forest79
                                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                  07-23-2023, 07:39 AM
                                • maanee11
                                  Help to get Lenovo BIOS bin file for Thinkpad T560
                                  by maanee11
                                  Hello Everyone,
                                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                  05-15-2022, 11:59 AM
