Schematic Boardview MS-7E06
  • ITFan
    • Sep 2021
    • 68
    Hello dear forum participants,
    I am looking for the board MSI Z790-p wifi (ms-7E06 V.: 2.1)
    the schematic and boardview.
    To the right of the USB port front header jusb4 connector on the mainboard a Schottky diode/MOSFET is defective and I would like to find out the exact designation and values.
    I found a Boardview from a MS-7D25 wich is similar. But i m not shure it is a n7002, Part Number on board Q17 there.
    Best regards
    ItFan
    PS: only the black cover seem to be broken, the contacts underneath seem ok. Can this be measured?
  • ITFan
    • Sep 2021
    • 68
    I just found out that it is a 2n7002 mosfet.
    However, I found this chip from many manufacturers (Hottech, Onsemi, NXP, Diodes Incorporated, etc...) with different values.
    Which (manufacturers) are preferably installed on MSI boards and which one can I use, because of different values?
    I have attached a picture because I don't know if I am allowed to insert a link from the company Reichelt!
    Which one would you recommend?
    Best regards
    ITFan
    • ITFan
      • Sep 2021
      • 68
      If anyone could help me find the correct chip, I would be so pleased. I'm still stuck on it. A boardview or schematic would also help me a lot.
      Best regards
      Itfan​
      • mon2
        • Dec 2019
        • 14522
        Each is compatible but if purchasing a new batch, select a brand name so you can support the higher current. That is, Onsemi has the ability to switch higher currents than Hottech but you may pay a few usd pennies more the component.
        • ITFan
          • Sep 2021
          • 68
          Hello mon2.
          Thank you very much for your reply.
          Have you seen the different values in the comparison in my other thread from today? A lot of the data is different there. That makes me unsure.
          Could I desolder a 702 from another msi board and solder it into said board or is that too much stress for the chip and better to buy a new one and solder it in?
          ​Best regards.
          ITFan
          • mkey0bc
            • Feb 2023
            • 3
            I have a few caps around the Nuvoton NCT6687D chip that are missing and I need to identify those
            Thanks!
              SMDFlea commented
              Editing a comment
              Thread merged.
          • PacoGT
            HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
            by PacoGT
            hello firends
            i search the schematic or boardview
            I have this motherboard, but I can't find the schematic or the boardview.
            The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
            So the computer doesn't turn on, and the 3V disappears after a few seconds.
            The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
            The new problem arose after removing the bad chip.
            3V and 5V remained together,...
            08-19-2025, 08:25 PM
          • hosain0489
            Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
            by hosain0489
            I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
            Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
            If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
            Thank you very much in advance!
            07-15-2025, 11:20 AM
          • re-atari
            Gigabyte GA-H110-D3A schematic/boardview needed
            by re-atari
            Hello all,
            Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
            This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
            02-24-2025, 06:45 PM
          • jonyhdtv
            HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
            by jonyhdtv
            Looking for schematic and boardview
            Model: HP ProBook X360 11 G3 EE
            Serial: SCG9114JG7
            Motherboard: L43774-601
            defect: touchscreen doesn't work (touch works on another computer)
            thanks to all​
            01-29-2025, 08:16 AM
          • jonyhdtv
            HP ProBook X360 11 G5 ee schematic and boardview thanks
            by jonyhdtv
            HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
            Model: HP ProBook X360 11 G5 EE
            Serial: SCG0164QLH
            Motherboard: L83950-601
            defect: no POWER
            thanks to all​
            01-29-2025, 08:11 AM
