BIOS REQUEST FOR HP Pro 3405 Microtower
  • OKRPKCOMP
    • Dec 2020
    • 439
    • PAKISTAN
    Hello Masters
    Board code: AAHD2-HY REV 1.02
    Serial no: CZC140D2RT
    3v 5v ram v , processor v, clocks, aossilation ok, fan spins, processor warns, but there is no display
    backup attached here
    Regards ​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12396
    Originally posted by OKRPKCOMP
    Hello Masters
    Regards ​
    There is no bios for this model on the HP home page.
      • 22084
      Hello Masters
      Regards
      The bios is split across 2 bios chips, 4MB and 2MB. Attached is a clean bios with no DMI. An old version of nbdmifit must be used to add the DMI. If you post your 4MB bios it might only need the ME firmware cleaning, that will retain the DMI so thats worth trying first .
      HP Pro 3405 Series
      SN CZC140D2RT
      FBYTE# 2U2W3E3N3Q3R3V3X474C4k5W5c676J6K6S6b6y727B7J7Q7T7W7m8C8S.H
      BUILDID# 11WWSNAW604#SABU#DABU
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
