ASUS PRIME H510M-K R2.0 BİOS
  • egelaptop
    • Jun 2015
    • 125
    • türkiye
    Friends, PRIME H510M-K R2.0 motherboard requires bios software. I do not have the original file. I would appreciate it if you could share it.
    • 21860
    Get the bios from Asus support, extract the body using UEFITool.
    https://www.badcaps.net/forum/troubl...rces-and-tools
    7.1. Desktops
    Retail motherboards can have a full BIOS image or only an update. Pre-built desktops will have DMI info, and mostly only a BIOS update.
    The full BIOS image may be packed into an UEFI Update Capsule. UEFITool with recognize the UEFI Update Capsule and allow you to extract the body in order to obtain the raw BIOS image.
    • egelaptop
      • Jun 2015
      • 125
      • türkiye
      Thank you for your help, I removed it with uefitools but unfortunately I did not get any results.
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        Yesterday, 04:20 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
