T48 (TL866II plus) Chip identification with OTP option?
  • Buzzfuzz2k
    • Nov 2023
    • 29
    • france
    Hello Guys
    I have a T48 programmer and i'm trying to read/write a W25Q256JVEQ chip.
    The Programmer identify and propose me 2 chips:
    - W25Q256JV@WSON8
    - W25Q256JV(OTP)@WSON8
    I have read the datachip of the chip and i don't really understand well the utility of the OTP ...
    I have made some tests:
    Test1: select "W25Q256JV@WSON8", read ok, modify the dump and reprogram.... Programming failed.... if i dump again, file is different from the first dump
    Test2: Select " W25Q256JV(OTP)@WSON8", read ok, modifiy the dump and program back.... Programming works.... if i dump again, dump is same as injected.
    The OTP file is larger, it's like if at the end of the 'nonOTC file (that finish at 01FFFFF0) you add lignes from 02000000 to 020002F0 with "FF"
    Can someone explain me what is OTP for and when to use it ?
    Many thanks
  • BigPete
    Panasonic LED TV Dead after EMMC dump
    by BigPete
    I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
    The dump was successful and the program finished without errors.
    I used a XGecu T48 to do the dump.
    I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
    One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
    I also shorted out the crystal of the adjoining ECU together and at one...
    03-15-2026, 03:08 AM
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • weisian
    VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
    by weisian
    I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
    1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
    2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
    03-12-2026, 05:54 AM
  • DrSAS
    ASUS UP6502ZA - 16MB SPI dump request - No boot
    by DrSAS
    I'm trying to recover a ASUS Zenbook Pro 15 Flip OLED (model UP6502ZA, serial R1N0CV06A262028, motherboard 60NB0W20-MB1030) which stopped booting after a Windows 11 update. The laptop powers on but there's no display and no POST.
    I have a CH341A v1.612 programmer with a WSON 6x5mm pogo adapter. I managed to get two identical consecutive reads, so I believe my corrupted dump is "reliable".
    I've spent the last few days trying to prepare a flashable image from the official ASUS bios file (UP6502ZAAS.312, 19MB) downloaded from their...
    12-24-2025, 04:23 PM
  • Boardview and Schematic Bot
    Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook P2 Specification for Upgrade or Repair
    This specification for the Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P2510-G2-M-54Q3 + Option Pack boardview and P2510-G2-M-54Q3 + Option Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-06-2024, 08:00 AM
