Please help. need clean me region for iMac A2115 EMC 3194 27 inch 5k 2019
  • premanpurimas
    • Oct 2016
    • 12
    • Indonesia
    Hi friends.
    Please help to clean me for this bios file of iMac 27" 5K 2019 (A2115 EMC 3194)
    Board number 820-01236.
    Pulled the bin file that i attached in this post from a normal same model iMac
    But with that file in my current iMac always restarting after several minutes of operation.
    And also i already tried several method to clean the me region of this file, but always end up with file system state "error" at ME Analyzer.
    Any help would be appreciated.
    Thanks in advance
  • rex98
    • Feb 2023
    • 1281
    • Mandaue CEBU, Philippines
    Originally posted by premanpurimas
    Hi friends.
    Thanks in advance
    try
    • premanpurimas
      • Oct 2016
      • 12
      • Indonesia
      Originally posted by rex98
      try
      thanks for the reply. will try this and and hopefully comes back with a good news.
      much appreciated
      • premanpurimas
        • Oct 2016
        • 12
        • Indonesia
        rex98 already tried the file to the imac
        and run perfectly without any restart
        system seems a little bit slow. probably because the os running from a hard drive
        anyway thanks a lot
        • premanpurimas
          • Oct 2016
          • 12
          • Indonesia
          hi rex98
          unfortunately with the file that you provided the camera is not working
          already tried reset nvram and still the same
          please help
        • premanpurimas
          • Oct 2016
          • 12
          • Indonesia
          hi. sorry for the lack of information from me.
          this imac is A2115 EMC 3194. Board number is 820-01236-a.
          Serial number is C02YL0YSJV3P
          • rex98
            • Feb 2023
            • 1281
            test it and reply.
            • premanpurimas
              • Oct 2016
              • 12
              • Indonesia
              test it and reply.
              hi, sorry for the late reply.
              unfortunately this unit already sent back to the customer with the current condition
              so much thanks for the support
              • lordmuken
                • May 2018
                • 54
                • Philippines
                test it and reply.
                Hello sir, i tried your bios file to my imac, but the problem is i cannot perform nvram reset, and fan high speed.
                i attached my orig bios, the problem is not turning on and no display.
                Serial number: C02Z1106JV40
                EMC: 3194
                • lordmuken
                  • May 2018
                  • 54
                  • Philippines
                  hello can anyone help me? the bios #7 works but with issues. like when i restart, shutdown or sleep the unit needs to unplug from the outlet inorder to turn on again, the wake wont work when the unit sleep.
                  can anyone repair my bios attached #9?
                  • omruu9
                    how to extract ME REGION AND Bios REGION from this hp File
                    by omruu9
                    hello this HP EliteBook 840 G5 Notebook PC i download this file hp website but its not extract in uefi tool its don't show any ME region or bios Region i want bios Region from this file any friend can provide tool for extract the desire region that i want thank you file is attach...
                    09-29-2021, 06:26 AM
                  • mich6el
                    Imac 2020 a2115 no image after reblays T2 Security chip
                    by mich6el
                    Hello! Has anyone encountered problems on the Imac 2020 27 inches with a T2 chip? I had to replace 2 T2 chips on two iMacs, the first one was successfully replaced, tested and given to the client. The second iMac after replacing the T2 is flashed, the system is installed through the target mod, it boots into the system, you can hear me tapping on the keyboard, but the image does not display (and to an external monitor​). I reballed the T2 chip, changed the processor, RAM, display. No positive result! My friend said that he had 2 such devices and on both of them, after replacing the T2 boards,...
                    04-22-2025, 02:05 PM
                  • jpreza
                    iMac 4K 2019 Logic Board schematic
                    by jpreza
                    Hey guys,
                    Looking for schematics for an iMac 4k 2019 model. For the life of me, I can't figure out why the display will not work. Everything is connected correctly, I don't see any caps or resistors that are damaged. I even swapped the display from another iMac 4k 2019 model to test it, and that display won't work either.
                    There are 5 diagnostic LEDs and only 4 light up. The last one does not.
                    Any help with schematics would be awesome!
                    JP
                    04-13-2023, 02:23 PM
                  • Forest79
                    by Forest79
                    However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                    07-23-2023, 07:39 AM
                    MEDION AKOYA P15645 + MS Office Home&Student 2019 Notebook Specification for Upgrade or Repair
                    This specification for the MEDION AKOYA P15645 + MS Office Home&Student 2019 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P15645 + MS Office Home&Student 2019 boardview and P15645 + MS Office Home&Student 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-06-2024, 05:00 PM
