Need bios dump for HP Desktop PC M01-F2025d
  • ammi
    • Mar 2017
    • 35
    • indonesia
    Hi...help me
    I need bios dupm for HP Desktop PC M01-F2025d
    code boar: AKALI Rev:A M11
    serial : 4CE232CX98
    here my old bios dump
    thanks
  • hoaca388
    Badcaps
    • Jan 2022
    • 12419
    Originally posted by ammi
    Hi...help me
    serial : 4CE232CX98
    thanks
    HP Desktop M01-F2025d Bundle PC (75S08PA)
    • ammi
      • Mar 2017
      • 35
      • indonesia
      thanks brother..
      • jinki_dadou
        • Oct 2023
        • 10
        • Algérie
        thank YOUUUUUUUUU BRO
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          by haitham sharabati
          Hello engineers 😀,
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          💀 Problem:😅
          08-07-2025, 04:54 AM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
