nedd bios dump prime b560m-k
  • beast4ever
    • Feb 2015
    • 174
    • egypt
    The site file is not working
    Unfortunately, the empty space is empty​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12281
    https://www.asus.com/vn/motherboards...=PRIME-B560M-K
    Extracting the PRIME-B560M-K-ASUS-2001.zip file, we have 2 files: PRIME-B560M-K-ASUS-2001.cap and BIOSRenamer.exe, we only care about PRIME-B560M-K-ASUS-2001.cap . Throw it into UEFI Tool, select Extract body.. Done.
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • haitham sharabati
      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
      by haitham sharabati
      Hello engineers 😀,
      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
      💀 Problem:😅
      - Device shows “Administrator Password”...
      08-07-2025, 04:54 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
