BIOS workstation HP Z8 G4 (motherboard FMB-1703)
  • glebcz
    • Nov 2023
    • 9
    • Uzbekistan
    I have a faulty workstation HP Z8 G4 (motherboard FMB-1703). The problem is that it won't start. The main problem is a BIOS malfunction. I took a BIOS dump from the faulty station. I also took a BIOS dump from another working workstation HP Z8 G4.
    Can you help me make a normal BIOS dump for a faulty workstation?
    bad station
    s/n: CZC037CV15
    working station
    s/n: CZC932800T
    SKU Number: Z3Z16AV
    MAC1: c8.d9.d2.24.72.90
    MAC2: c8.d9.d2.24.72.93
  • glebcz
    • Nov 2023
    • 9
    • Uzbekistan
    Re: BIOS workstation HP Z8 G4 (motherboard FMB-1703)
    I wrote the serial number wrong.
    bad station
    s/n: CZC9379L62
    • hoaca388
      Badcaps
      • Jan 2022
      • 11653
      Originally posted by glebcz
      i wrote the serial number wrong.
      Bad station
      s/n: Czc9379l62
      bbbbbbbb
      • glebcz
        • Nov 2023
        • 9
        • Uzbekistan
        Originally posted by hoaca388
        bbbbbbbb
        I flashed the BIOS dump you sent. But when the power supply is connected to the station, it immediately produces 5 long and 2 short signals (5 red and 2 white signals are duplicated on the LED).
        This condition indicates that the embedded controller does not have valid firmware.
        Can you fix this?
        • hoaca388
          Badcaps
          • Jan 2022
          • 11653
          Can you fix this?
          HP Z8 G4 Workstation
          • glebcz
            • Nov 2023
            • 9
            • Uzbekistan
            Updated BIOS firmware. But now the station gives different signals. After flashing the BIOS, the computer emits 3 long and 4 short beeps. Can this be fixed in the BIOS?
            • hoaca388
              Badcaps
              • Jan 2022
              • 11653
              NO. you try find hardware error
              • testato
                • Oct 2024
                • 10
                • germany
                Hi to all,
                I have the same machine, Z8 with FMB-1703 MB.
                I have some question:
                1- there is two Bios chip onboard ? Also in your .rar file I see two .bin
                2- what does this two chip ? I need flash the two or only one is enough ?
                3- the two chip is the two that are visible in my attached photo ?
                4- if I flash by a Ch341 your original file from the first post, without modification, will the machine work ? I imagine that only the serial, mac, ecc will be different but working.
                Thanks for your help
                • testato
                  • Oct 2024
                  • 10
                  • germany
                  this is my two dump
                  • testato
                    • Oct 2024
                    • 10
                    • germany
                    My serial: 4CV010WZG2
                    My History:
                    The workstation work regularly until I changed something in the bios (Sure Start off, and some other think that i not remember)
                    When i saved it autorestart, and loop reboot every 20/30 seconds, whitout video and whitout keyboard, without led error.
                    Ater that i tried to dump the bios whitout desolder, after some dump try the workstation stop the loop reboot and start to blink led 5RED+2WHITE.
                    Now i desoldered the two flash chip and dumped.
                    Under the largest one I found oxidation under the pins. now i cleaned all.
                    I wait for your tips, maybe i can try to resolder the two chip without modify it ?
                    You can understand if my two orginal .bin are corrupted ?
                    Or i can wait for your new two .bin and flash + solder directly you version ?
                    Thanks a lot for your help
                    • testato
                      • Oct 2024
                      • 10
                      • germany
                      I flashed your #5 files, the Bios and the EC.
                      Now the powersuply switch on and off in a rapid strange way
                      • glebcz
                        • Nov 2023
                        • 9
                        • Uzbekistan
                        1. Have you tried flashing the old firmware back? Is the motherboard not working the same way? 2. How is the power supply behaving? Does it shut down immediately when you turn it on?
                        • testato
                          • Oct 2024
                          • 10
                          • germany
                          NOw the power remain always off
                          Mau
                          Maybe i have also a powersipply problem
                          If i remove power supply from the case it switch on the fans and the green led, but may this is a fake info ?
                          You are repaired your MB ?
                          • glebcz
                            • Nov 2023
                            • 9
                            • Uzbekistan
                            No. I didn't rebuild the motherboard.
                            • testato
                              • Oct 2024
                              • 10
                              • germany
                              Do you know if the 12V must be present always ? Or the 12V will switched ON after the POST ?
                              If I press the power button, only the 5V will be present.
                              Maybe I can connect an external 12V in parallel to the original 12V
                              • glebcz
                                • Nov 2023
                                • 9
                                • Uzbekistan
                                If I disconnect this connector, the power supply turns on. 12V is supplied from the other connector. If this connector is plugged in, the power supply goes into protection. I have not been able to figure out what the cause is yet. It could be a motherboard problem.
                                • testato
                                  • Oct 2024
                                  • 10
                                  • germany
                                  Have you tried to remove the 2 Cpu and all the Ram ?
                                  • glebcz
                                    • Nov 2023
                                    • 9
                                    • Uzbekistan
                                    Yes. But it looks like the problem is with the motherboard.
                                    I'm getting another HP Z8 G4 workstation next week. I will test all the components on the other workstation
                                    • testato
                                      • Oct 2024
                                      • 10
                                      • germany
                                      I played with the connector and also in my case the connector that switch off the power supply is the one like yours.
                                      On this connector there is 12V, 5V and 3V.
                                      Is the only one with 3V inside.
                                      I attached an external supply in parallel on the 12V metallic pin and the green led inside power supply switched On, and the MB try to start the fans.
                                      Maybe i have only a Powersupply problem.
                                      You can try the same ?
                                      Your green led inside power supply is On ?
                                      For now my hypothesis is that the power supply already had some random problem, and exactly when i changed bios, after i press Save, it loose the supply and corrupt bios.
                                      • testato
                                        • Oct 2024
                                        • 10
                                        • germany
                                        Niet,
                                        it's not the Power Supply, i replaced it
                                        So it's my mainboard
                                        • glovecaps
                                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                          by glovecaps
                                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                          11-25-2024, 04:23 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • oragano
                                          ASUS ex-b250-V7 motherboard bios corrupted - by me
                                          by oragano
                                          hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                                          So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                                          i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                                          10-17-2024, 02:53 AM
                                        • AkaBukai
                                          Is it okay to flash stock bios onto the motherboard's BIOS?
                                          by AkaBukai
                                          Hi there,
                                          I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                                          The little LED on the power button is flashing slowly and nothing happen.
                                          This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                                          So I decided to flash the BIOS using a cheap programmer.
                                          And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                                          I also...
                                          12-19-2024, 12:15 PM
                                        • EpicLPer
                                          HP Z2 SFF G9 Workstation (5F0D1EA) - BIOS corruption fix
                                          by EpicLPer
                                          Heya,
                                          I'm currently trying to fix a “HP Z2 Small Form Factor G9 Workstation (5F0D1EA)” after HP issued a warning that some models may become entirely unbootable if left on specific old versions. The exact issue happened to the one I got right now: https://support.hp.com/us-en/documen...235-8577455-16
                                          I've already desoldered and dumped the broken BIOS, over on the "level1techs" forums someone already took a look at it and sadly couldn't fix it either 😥 Still grateful of them taking a look however!
                                          I guess the current BIOS/dump truly seems to be...
                                          05-08-2025, 03:41 PM
