HP(All in one) 24-df0086nf (failed during bios updated now black screen)dump provided
  • il60
    • Jun 2019
    • 25
    • France
    i have an HP (All ine one) 24-df0086nf , i updated the bios, but the computer crash during update
    BOARD : DAN14CMB6E0 rev E
    now black screen
    may you repair my bios in order to have work bios but keep all hp information (DMI sn..)
    dump attached,
    Again big thank you !!!
    as alway, for dump work, i will make donation for this wonderfull forum
  • hoaca388
    Badcaps
    • Jan 2022
    • 12268
    Re: HP(All in one) 24-df0086nf (failed during bios updated now black screen)dump prov
    BOARD : DAN14CMB6E0 rev 5
    now black screen
    dump attached,
    Serial number ?
    • il60
      • Jun 2019
      • 25
      • France
      Originally posted by hoaca388
      Serial number ?
      8CC0222J62
      thanks
      • il60
        • Jun 2019
        • 25
        • France
        any new ?
        • hoaca388
          Badcaps
          • Jan 2022
          • 12268
          any new ?
          There is no bios for this model on HP homepage
          • il60
            • Jun 2019
            • 25
            • France
            Ok thanks
            that mean that we can"t do something ?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12268
              Ok thanks
              Can only wait for someone to share the bios file they have.
                • 21679
                any new ?
                Make a USB recovery drive and try it
                Same issue fixed - https://www.badcaps.net/forum/showthread.php?t=123248
                https://www.badcaps.net/forum/showthread.php?t=123248 4-in-1
                • il60
                  • Jun 2019
                  • 25
                  • France
                  thanks for help, i will try it,
                  but before to try it and rebuild the computer, i find this :
                  https://www.badcaps.net/forum/showthread.php?t=104382
                  provided virgin bios by SMDFlea
                  may you load me SN to this bios file ?
                  (this is the exact same motherboard)
                  thanks
                  dmi : 20WW1ZAT602#SABF#DABF
                    • 21679
                    try.
                    • il60
                      • Jun 2019
                      • 25
                      • France
                      thanks you very much i will try it
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • mitchw
                        HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                        by mitchw
                        Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                        After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                        After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                        I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                        04-29-2025, 03:45 PM
                      • Technodoc
                        ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                        by Technodoc
                        Asus laptop G614JZ-N3012W Rog Strix with i7
                        Mainboard G634J-PMV-VGT
                        6050A3441302-MB-A01
                        2023-02-10
                        Power button works okay....power light goes on
                        Red "bottom" leds go on
                        Charging led works
                        Fans do not spin, capslock key does nothing, screen stays black
                        I would like to program the bios again, to rule out a corrupted bios.
                        However I run into a size error
                        The bios chip is a Winbond 25R256JVEN
                        Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                        02-24-2025, 04:46 AM
                      • il60
                        zbook 17 g3 Crach During Bios update, now black screen (dump bios provided)
                        by il60
                        i have an zbook 17 g3, i updated the bios, but the computer crash during update
                        now black screen
                        dump attached,
                        big thank you !!!...
                        06-09-2023, 09:51 AM
                        by Vesko356
                        08-11-2023, 03:27 AM
