Need Bios HP AIO PC 24-DF0214
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    Any one have dumped bios file for HP AIO PC 24-DF0214. It has an error says:
    The System BIOS update failed
    Unable to open BIOS Image File
    I tried to get a bios on HP support but I an having a problem looking for the exact BIOS Bid for my unit. I cant extract the bios inside Bios-System Firmware
    Bios need needed is with BID : 86F3
    • 22293
    Re: Need Bios HP AIO PC 24-DF0214
    Same issue solved by one of our members https://www.badcaps.net/forum/showthread.php?t=123171 .Attached is your backup edited with the entries showing bios upgrade failed filled with FF`s.
    Run the bios update from support to make a recovery USB ,if it doesn`t run but only extracts to the SWSetup folder on your C: drive try again on another PC. Running that exe on my dell optiplex with an AMI bios makes it lock up and bluescreen. If you can`t run the exe make a recovery USB with the "HP PC Hardware Diagnostics 4-in-1 USB Key" instead there`s a link to it at the bottom of this post https://www.badcaps.net/forum/showpo...50&postcount=1 ,get all of the Additional Softpaqs as well
    • ronelex
      • Oct 2016
      • 195
      • Philippines
      thank you, I will study that thread
      • to5it0
        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
        by to5it0
        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
        I have opened the laptop and identified the main BIOS chip...
        10-24-2025, 01:35 AM
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
      • Yacine007
        HP victus 16 update bios failed
        by Yacine007
        hello dear friends
        I recently bought this motherboard and I'm having a lot of problems.
        - The Wi-Fi doesn't appear in the Network Card in Device Manager (The Wi-Fi card and the Wi-Fi work fine when I installed the old motherboard)
        - The hard drive is missing when i reboot the system and reappears when i reboot again (crtl+alt+del).
        - When I tried to do an internal BIOS update it doesn't work it always fails.
        Can someone help me update the BIOS or give me a new clean BIOS?
        hp Victus 16-e0xxx
        SN 5CD2050PSQ
        Thank you in advance...
        09-28-2025, 05:30 AM
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        Hi everyone,
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
      • Citymin
        NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
        by Citymin
        My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
        The charging red LED lights up, but the charging screen doesn't show any indication.
        When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
        (I've tried removing the battery and resetting the device, but the issue persists.)
        NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
        PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
