MSI MAG B550 TOMAHAWK - CPU error, boardview REQ
  • Zakyn
    • Aug 2023
    • 12
    • Česko
    Hi, I've MSI MAG B550 TOMAHAWK, which stuck on CPU error (red EZ debug LED is on).
    1. I've tried to flash BIOS from USB with no success (stuck on red LED blinking).
    2. No component is overheating.
    Does anyone have boardview of this mobo? I would like to trace the problem, but without boardview is pretty hard task. Thanks for any help.
  • McWhitePink
    • Apr 2023
    • 103
    Re: MSI MAG B550 TOMAHAWK - CPU error, boardview REQ
    Likely to be a common issue with this board. I have 4 boards have the same issue.
    one of them was flashed with latest BIOS and works alright, but when I tried to flash it the second time the same issue happened.
    If you see the flash back LED blinking you should wait for more time. it takes minutes to go next step
    • Zakyn
      • Aug 2023
      • 12
      • Česko
      I have waited 15-30 minutes each try, tried different USB sticks with various BIOS versions. I managed to get schematics and boardview so I will track singals of power sequence and hopefully find out what is going on.
      • McWhitePink
        • Apr 2023
        • 103
        I think you are getting the same issue as I have for 4 of my B550 TOMAHAWK, onboard flashback doesn't work correctly for some reason. I flash them with offline SPI programmer, they are now all come back to normal.
        Same symptom, stuck on CPU debug light. I checked all voltage and signals, all seems working good. Then I just try my luck to flash the BIOS, and it works.
        • Zakyn
          • Aug 2023
          • 12
          • Česko
          Do you still have them? I accidentaly erased SPI flash memory, without backup Can I ask you for favor? I really need dump of that memory. Its part U46.
          I managed to get boardview and schematic:
            • 31046
            go to msi - unlike a lot of companies there bioses look to be complete.
            i'v not looked at a B550 but i can tell you the B350 bios is complete at msi site
            btw - this may interest you
            • Zakyn
              • Aug 2023
              • 12
              • Česko
              Thanks, I will take a look on that.
                • 31046
                incidentally,
                there is a pattern to this,
                a lot of modern boards - specially MSI brick a lot.
                the problem is trying to flash the bios from windows - dont ever use the software they supply that updates the bios from windows.
                dont use *any* bios tools from windows - only from a bootable dos device.
                even the flasher built into the bios - Mflash? is said to be unreliable.
                if you want evidence, just type "msi bios recover" into a search engine!!!
                • f-bone
                  • May 2013
                  • 96
                  • Greece
                  would love a copy of U46 too
                  • f-bone
                    • May 2013
                    • 96
                    • Greece
                    here is my u46 dump.. I see the remont forum has some info but I am not registered to see details.
                    U46 https://www.badcaps.net/forum/showthread.php?t=125760
                    • McWhitePink
                      • Apr 2023
                      • 103
                      For MSI B550 you don't really need to have the BIOS dump, you can directly flash the BIOS you download from MSI website.
                      I compared the dump with the one downloaded, they are identical binary file.
                      • Actionkindaguy
                        MSI MEG Godlike x570 motherboard - need schematic and boardview, USB3 error
                        by Actionkindaguy
                        MSI MEG Godlike x570 motherboard - need schematic and boardview. I have accidentally plugged in the wrong usb plug into a usb3.0 connector on front panel of PC resulting in temporarily shorting out the port. (I know it was really stupid, It was dark in my room and was rushing). I shutdown the computer and now after an immediate restart I get an overcurrent error on boot up saying my PC will shut down in 15 seconds. If I let the computer sit for about 35 minutes, I then can boot the PC without getting error. What I am hoping to find out is what parts were affected by my stupidity. Anyone have any...
                        05-06-2024, 09:41 AM
                      • Sus256
                        HISENSE 65E7KQ PRO - no boot
                        by Sus256
                        Hi all!
                        HISENSE 65E7KQ PRO
                        RSAG7.820.13512 - chassis
                        MT9618BAATAB - cpu
                        RSAG7.820.12059 - power
                        HD650Y3U77 - panel
                        KLM8G1GETF - emmc
                        The TV does not turn on, the standby indicator is on. All voltages are present.
                        Emms is dead. Not readable, not detected.
                        Replaced emmc.
                        But with another dump there is no launch
                        Terminal log
                        UART
                        AC_ON
                        RPMB key is not yet programmed
                        HASH1_VERSION=0x00000000 64bit
                        E-B
                        FDE enabled
                        layout pattern onebin by SAR7,0...
                        06-01-2025, 02:11 AM
                      • semaca
                        MS - 7D75 ver:1,1 schematics and boardview for MSI MAG B650 Tomahawk WIFI
                        by semaca
                        Does anyone has schematics and boardview for MSI MAG B650 Tomahawk WIFI ?
                        Semaca
                        08-07-2025, 07:22 AM
                      • baas62
                        Burnt resistor MSI B550 Tomahawk Max
                        by baas62
                        Hello everyone
                        I have an MSI B550 Tomahawk Max Wi-Fi motherboard that has burned out components. See photos below.
                        I tested the rest of the board, and everything seems to be working properly and stable. I tested it in-game with a 1650 GPU, just in case, and in Cinebench.
                        I didn't install an NVME SSD on the first port but only a sata 6gb classic 2.5 inch ssd
                        I checked the warranty on the MSI website, and the board is still under warranty until May 2026, but unfortunately I don't have the receipt to request an RMA.
                        Is there anyone...
                        08-02-2025, 01:38 AM
                      • tvist
                        I nees help with boardview rog strix b550-a gaming rev1.0
                        by tvist
                        Hello everyone! I have a rog strix b550-a gaming rev 1.0 motherboard being repaired and I can't find boardview for this board. I appeal to you, dear participants in this matter, help.
                        06-06-2025, 04:08 AM
