MSI MAG B550 TOMAHAWK bios
  • f-bone
    • May 2013
    • 96
    • Greece
    here is my u46 dump..
    • 21844
    Re: MSI MAG B550 TOMAHAWK bios
    https://www.msi.com/Motherboard/MAG-...K/support#bios
    Rename the file extension to *.bin
    • f-bone
      • May 2013
      • 96
      • Greece
      Hi!
      Isn't this the main BIOS? U46 is a small 2mbit spi for the IO controller and I believe it gets corrupted thus we require a working dump (unless someone knows how to extract it from the main bios).
      • nbdatacenter
        • Jul 2018
        • 5
        • turkey
        maybe this will help.​
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • mkdj
          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
          by mkdj
          Dear all,
          I have a ASUS ZenBook UX480F with the following symptoms:
          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
          10-19-2025, 04:41 AM
        • Habble7
          I need a BIOS dump for the Samsung S49CG934SU monitor
          by Habble7
          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
          Suspected Cause:
          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
          by haitham sharabati
          Hello engineers 😀,
          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
          💀 Problem:😅
          - Device shows “Administrator Password”...
          08-07-2025, 04:54 AM
        • Citymin
          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
          by Citymin
          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
          The charging red LED lights up, but the charging screen doesn't show any indication.
          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
          (I've tried removing the battery and resetting the device, but the issue persists.)
          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
