PRIME H610M-K D4 bios bin
  • spiderman061
    • Nov 2020
    • 19
    • Türkiye
    13th generation processor does not display. I need bios bin file.
  • shibu
    • Apr 2016
    • 28
    • uae
    Re: PRIME H610M-K D4 bios bin
    try and replay
      • 20869
      https://www.asus.com/motherboards-co...IME-H610M-K-D4
      Use a hex editor and delete offsets 0 - FFF or Use UEFITool to remove the 4kb CAP header. https://github.com/LongSoft/UEFITool..._A55_win32.zip
      Open the bios with uefitool, right click on AMI Aptio Capsule, Extract Body .
      • spiderman061
        • Nov 2020
        • 19
        • Türkiye
        Originally posted by shibu
        try and replay
        thanks but its longer than bios error
        sorry but but support
        • spiderman061
          • Nov 2020
          • 19
          • Türkiye
          thanks but i applied but i couldn't get display, no bios
          • spiderman061
            • Nov 2020
            • 19
            • Türkiye
            i didn't found, plesase help me
            • spiderman061
              • Nov 2020
              • 19
              • Türkiye
              I solved the problem myself, it works 100%
              • Andres espinola
                • May 2024
                • Argentina
                Hi, I am in the same situation! You fix the problem?
                I am from Argentina, my english is limited.
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • Bloodhoundje
                  by Bloodhoundje
                  03-16-2024, 03:12 PM
