Hp Elite Mini 800 G9 Bios Password
  • emersonsoares
    • Jun 2024
    • Brazil
    Hello, I need help unlocking the BIOS password on my hp elite mini 800 g9.
    I already tried the CMOS button, removed the battery and it didn't work either.
    S/N: 8CC3320YXQ​
    • peste
      • Dec 2016
      • 12841
      • ROMANIA
      S/N: 8CC3320YXQ​
      post the original bios, you need an SPI programmer, watch a video as an example..https://www.youtube.com/watch?v=DWWigscuQDY
      • emersonsoares
        • Jun 2024
        • Brazil
        Original bios in zip file.
        • Wålleischii
          • Nov 2024
          • Usa
          Did it work? I'm in the same situation
          • dg01
            • Oct 2012
            • 14
            • MALTA
            Can someone be kind enough to help remove the bios password from attached file
            PC --> elite mini 800 G9
            sn -->>8cc3252cmf
              • 20966
              Read -> https://www.badcaps.net/forum/troubl...before-posting ,post the PC serial number please.
              • dg01
                • Oct 2012
                • 14
                • MALTA
                #27
                sn -->>8cc3252cmf
                some additional information for my bios request (HP elite MINI 800 G9 desktop PC) see attached picture
                there are two chips a winbond 25Q256JVEN located between the 2nd m.2 drive and cpu and a GIGADEVICE 25B256DYIG located near the front speaker
                In addition there is a CMOS switch and a battery on the motherboard, can these be used to clear the bios from the locked unknown bios password ?
                the bios file I attached previously is the content of the winbond chip
                Thanks in advance for any help given.
                • dg01
                  • Oct 2012
                  • 14
                  • MALTA
                  #28
                  update will appreciate a working bios and prvrom chip dump
                  attached an additional few pictures of the motherboard top, bottom, model and prvrom chip
                  • trunguntilyou
                    • Aug 2022
                    • 328
                    • Vietnam
                    #29
                    ​sn:MXL5023QMN
                    Please unpass
                    • widdx
                      • Aug 2024
                      • 5
                      • Sweden
                      #30
                      Has anyone been able to remove passwords from these machines yet? I'm looking to get a couple for a cluster, can get them cheap with bios passwords but i'd need to get rid of those in order to remove secure-boot.. I have the tools required to flash, but need to know if it's been done or not.
                      • rex98
                        • Feb 2023
                        • 1278
                        • Mandaue CEBU, Philippines
                        #31
                        sn:MXL5023QMN
                        Please unpass
                        First flash the main only do not flash the EC. if it doesn't work in main only. try flashing the EC i provided.
                        its already clearME so it should boot in same other units
                        let me know if it boots to MPM
                        • danish8717
                          • Dec 2021
                          • 26
                          • united arab emirates
                          #32
                          Hi , can u upload this again want to try on my pc the file is is not downloading,
                          • widdx
                            • Aug 2024
                            • 5
                            • Sweden
                            #33
                            Here you go, i'm trying on my machine as we speak. No luck with only main, flashing EC atm..
                            • volinakis
                              HP Elite Mini 600 G9 Desktop PC Bios Password
                              by volinakis
                              Hi, I need help to remove bios password please.
                              Name: HP Elite Mini 600 G9 Desktop PC
                              S/N: 8CC4131WJ8
                              Prod Id: 4C5J7AV
                              I did usual modifications to enter in MPM mode but with modifications it restarts several times then when it boots it appears message: "Bios Identity Data Recovered The BIOS has recovered its identity data from the Embedded Controller due to data mismatch" and did not enter in MPM mode.
                              I attach main and EC backups, maybe Badcaps Masters can help me, thank you in advance.
                              post moved......
                              09-10-2024, 12:34 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • traxformania
                              TONGFANG "GM7TG7P" Bios Password Problem?
                              by traxformania
                              I tried :
                              -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                              11-15-2023, 07:32 AM
                            • tlindi
                              Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                              by tlindi
                              Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                              Ack
                              Ack
                              01-30-2025, 04:26 AM
                            • Nopslide
                              by Nopslide
                              04-01-2024, 04:27 PM
