MSI MPG B550 Gaming Carbon Wifi
  • tccyo22
    • Oct 2019
    • 73
    Looking for someone who would be kind enough to share a known working BIOS dump from this motherboard model. Currently have one and 90% of the BIOS is empty data
  • peste
    • 13343
    • ROMANIA
    Re: MSI MPG B550 Gaming Carbon Wifi
    go to the MSI website, according to the model above and find the bios there...
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • Bloodhoundje
      by Bloodhoundje
      03-16-2024, 03:12 PM
    • helpmepleasethanks
      Thinkpad T440P bios repair after WIFI whitelist mod
      by helpmepleasethanks
      As per the the rules, here are the specifications of my laptop :
      • Make and model number : Thinkpad T440P
      • Serial number (S/N) : PB-03A7V7
      • Model type - Model (MTM) : 20AW-S2N800
      • Bios version : 2.50 (not 100% sure, that's what I remember)
      Here is the problem, and the events leading to it :
      1. Upgrade screen, keyboard, trackpad, RAM and CPU
      2. Reboot and use the laptop for a bit : everything is working fine
      3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
      4. Boot up the device : bios warning, as expected
      5. Shutdown the device again (no power)
      6. Connect the 8-pin clip of a CH341a
      01-09-2025, 12:09 PM
    • tomswildman
      Msi Mpg z490 gaming carbon wifi part id
      by tomswildman
      Hello all, help please id manufacturer and code for part labeled FK=8A. Part is located near the VRM at the bottom assuming some kind of 5 volt controller. Motherboard has shorted 5 volts and this is possibly the culprit along with a 10 ohm resistor nearby . Motherboard is MSI MPG Z490 Gaming Carbon wifi. Thank you!😊...
      09-27-2025, 07:49 PM
    • f-bone
      MSI MPG B550 Gaming WiFi Edge IO bios
      by f-bone
      Hi guys,
      I had this one for repair and discovered that the IO controler (nuovoton) was dead (shorted). Replaced it and flashed the main bios using my programmer (the usb method was not working the LED flashed for 5" and stoped) but the motherboard is still dead, no power although 3.3V at JFP1 and no LED activity.
      There is a small MXIC 25V2033F next to the IO controller which I believe could be corrupt.
      Is it possible to find a dump?
      thank you in advance,
      BR,
      George
      11-07-2023, 03:20 AM
