MSI MPG B550 Gaming WiFi Edge IO bios
  • f-bone
    • May 2013
    • 96
    • Greece
    Hi guys,
    I had this one for repair and discovered that the IO controler (nuovoton) was dead (shorted). Replaced it and flashed the main bios using my programmer (the usb method was not working the LED flashed for 5" and stoped) but the motherboard is still dead, no power although 3.3V at JFP1 and no LED activity.
    There is a small MXIC 25V2033F next to the IO controller which I believe could be corrupt.
    Is it possible to find a dump?
    thank you in advance,
    BR,
    George
  • PCBite
    • May 2025
    You probably found another solution in the meantime, but nevertheless:
    I dumped my memory of a non working edge board. It is the same as the one posted here: Link
    • mkdj
      What should I do after having flashed a BIOS?
      by mkdj
      Dear all,
      I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
      Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
      09-09-2025, 09:45 AM
    • Bloodhoundje
      by Bloodhoundje
      03-16-2024, 03:12 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • Loli Popu
      DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
      by Loli Popu
      Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
      12-13-2024, 03:28 AM
    • drux
      Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
      by drux
      I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
      Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
      These models have AMI/Aptio BIOS.
      Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
      11-03-2024, 01:18 AM
