HP TouchSmart 610-1030y bios
  • khelane
    • Apr 2015
    • 172
    • xxxx
    hi all
    plaese i need a dump file for this device :
    DA0ZN9MB6H0 REV:H
    tnx
    • 21847
    Re: HP TouchSmart 610-1030y bios
    Originally posted by khelane
    hi all
    DA0ZN9MB6H0 REV:H
    tnx
    If you have a backup post it here.
    • khelane
      • Apr 2015
      • 172
      • xxxx
      uploaded
        • 21847
        uploaded
        try this one https://forum.laboneinside.com/viewtopic.php?t=2204
        • khelane
          • Apr 2015
          • 172
          • xxxx
          Thankful
          BIOS has been programmed and the device is working.
          The main problem of the device is that USB and LAN do not work. According to the customer, the device was turned off, but the charger was connected and the LAN cable was connected to the modem. Meanwhile, a lightning strike occurred and the modem was turned off, and two ICs inside the modem burst. After working with the device for a few days, neither the USB ports nor the LAN are working, as well as the touchscreen.
          Current USB voltages have the same voltage as the data bases. But nothing can be detected inside Windows, inside Mini Windows and BIOS have been tested. According to the schematic of the device, the USB ports go directly into the chip. I took a backup of the BIOS of both devices, I said it might be from the BIOS, but I downloaded this version and programmed it, it was the same, only the BIOS of the controller remained, which was not included in the download file.
          Now I'm waiting to find and download both bios. If it doesn't work, there is a strong possibility that the chip is mentioned.
          There is no burn or damage on the motherboard, and the motherboard goes into Windows and works without problems
          Only the touch screen and USBs and LAN do not work
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
            by haitham sharabati
            Hello engineers 😀,
            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
            💀 Problem:😅
            - Device shows “Administrator Password”...
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
