optiplex 7000
  • volinakis
    • Jan 2021
    • 2873
    • N/A
    Originally posted by ali0robot
    thank you but when I wanna open this file in fit it gave an error
    lol, why opening ME firmware with FIT? Open your bios backup, decompose it, save, replace ME Sub Partition with ME firmware hoaca388 provided you, rename it as ME Sub Partition, load saved config and hit Bulid tab! Read guide about how to use FIT!
    • ali0robot
      • Mar 2023
      • 83
      • N/A
      thanks for help, I now this routine but for new generation is different method. when I use this method it gave me error
      • volinakis
        • Jan 2021
        • 2873
        • N/A
        that means you messed up with Bios_Region, you just had to replace ME Sub Partition with ME Fw provided. There's no "different method" it's the same as the older models only you can't skip generating intermediate files.
        • ali0robot
          • Mar 2023
          • 83
          • N/A
          I am following same thing that I was using in past generation and i didn't have any problem until intel flash image 15 but 16 look different for me. I done it like your explanation but gave me error
          • volinakis
            • Jan 2021
            • 2873
            • N/A
            optiplex 7000 has 2 bios chipsets, you have to merge files to get full bios.
            • ali0robot
              • Mar 2023
              • 83
              • N/A
              #26
              Optiplex 7000 has 2 bios chipsets, you have to merge files to get full bios.
              but the problem is that this is EC bin, I didn't touch the main bios bin because I wanted to remove the bios password. problem is that I missed the EC bios bin and mistakenly I programmed another machine's EC bios bin into another one without taking backup. after programming machine started to spin so fast and gave me three amber and six white led cod that showed bios file was not correct. one professional guy told me if you can clean me region in EC bion maybe the problem will solve
              • volinakis
                • Jan 2021
                • 2873
                • N/A
                #27
                just post both backups along with serial no. , you have no clue what bios wants from you. That one trying to fix half of bios with FIT is EPIC!
                • ali0robot
                  • Mar 2023
                  • 83
                  • N/A
                  #28
                  they are my both bios bin
                  service tag: czxgwp3
                  OptiPlex 7000 micro
                  sorry if the service tag is not same with bios it's mean that I lost original file because I tried several bios bin
                  thanks in advance
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12316
                    #29
                    OptiPlex 7000 micro
                    thanks in advance
                    OptiPlex 7000 Micro
                    Service Tag: CZXGWP3​
                    ​https://www.badcaps.net/donate
                    • ali0robot
                      • Mar 2023
                      • 83
                      • N/A
                      #30
                      Originally posted by hoaca388
                      OptiPlex 7000 Micro
                      after programming both chip power led gives 3 amber and 6 white
                      • volinakis
                        • Jan 2021
                        • 2873
                        • N/A
                        #31
                        OptiPlex 7000 micro
                        thanks in advance
                        There are 2 bios versions for your laptop, try them both. Check bottom label for model, EVT_X02_CHPB_64 is for models 0AC2,0ACC and EVT_X02_64 is for models 0AC2,0ACC. Write both chipsets.
                        • ali0robot
                          • Mar 2023
                          • 83
                          • N/A
                          #32
                          thank you for help but unfortunately gives a 3 amber and 6 white
                          • kuiri
                            • Jun 2024
                            • 11
                            I tried one and the computer booted (before it would have no video and a high speed fan) but the BIOS says "Unidentified System" where the model should go.
                            Mine is the DDR5 with a full sized - standard dell charger
                            I think there's a DDR4 variant also.
                            Edit: I tested both variants and in both it says "Unidentified System"
                            Edit: After updating to the latest BIOS, and pressing Alt + F on boot, I got the menu to select between the Regular Optiplex 7000 Alder Lake or the China Version with HDD Protection.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12316
                              #34
                              OptiPlex 7000 Micro
                              Service Tag: 9Z1M3Q3​
                              • ali0robot
                                • Mar 2023
                                • 83
                                • N/A
                                #35
                                mine is tiny model and I also change bios chip and reprogram both chip but just gives three amber and six white led light
                                • kuiri
                                  • Jun 2024
                                  • 11
                                  Try with a different programmer. I flashed the CHPB Variant and it let me update the bios & firmware to the latest version using the RCV file.
                                  I only have one problem where the power on light doesn't stay on. It only turns on when I press the button to power the machine on, but the lights remain off.
                                  • ali0robot
                                    • Mar 2023
                                    • 83
                                    • N/A
                                    #37
                                    could somebody do me a favour and tell me if we copy both EC and Main bios from one OptiPlex 7000 micro to another one, second pc should work or not.my knowledge is not enough about this
                                    • peste
                                      • 13550
                                      • ROMANIA
                                      #38
                                      it might not work, you need to clear the "ME region" of the bios..because it needs to pair with the PCH...and the DMI information needs to be passed from one bios to another...
                                      • ali0robot
                                        • Mar 2023
                                        • 83
                                        • N/A
                                        #39
                                        Hi guys,
                                        finally I find good bios for my tiny pc, if anybody need can use it. it's also in manufacturing mode
                                        • jOHN112
                                          • Jul 2025
                                          • MACOMB
                                          #40
                                          I currently have a Dell Optiplex Micro 7000 12th Gen CPU that has a bios password on it and am trying to remove. I'm asking for the info on the best possible way to do so. I have tried to used Badcaps Patcher which indicates hex pattern not recognized. Dell Bios Tools patcher also says the intel signature is not found. Any resources to look at for this would be appreciated . Thank you for your info and time.
                                          Service Tag is FRV96S3-8FC8
                                            DELL OptiPlex 7050 OptiPlex 7000 i5-7500 Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 7050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7050 boardview and OptiPlex 7050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            DELL OptiPlex 7060 OptiPlex 7000 i5-8500T Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 7060 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7060 boardview and OptiPlex 7060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            DELL OptiPlex 7080 OptiPlex 7000 i7-10700 Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 7080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7080 boardview and OptiPlex 7080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            DELL OptiPlex 7060 OptiPlex 7000 i5-8500 Specification for Upgrade or Repair
