A540-24API All-in-One Bios
  • izaak94
    • Mar 2019
    • 140
    • mexico
    hello... could you help me with the update of this .bin, since windows does not allow the update
    Type F0EM
    S/N YJ012C2A
  • izaak94
    • Mar 2019
    • 140
    • mexico
    Re: A540-24API All-in-One Bios
    any solution?
    • peste
      • 13561
      • ROMANIA
      Originally posted by izaak94
      any solution?
      the posted bios is corrupt...try this...
      • izaak94
        • Mar 2019
        • 140
        • mexico
        Can this file be saved or do I have to modify something? , the previous one published does not send an image only with mine, but I found this one on the official site that was not available before, apparently it is identical to the original mine
        • izaak94
          • Mar 2019
          • 140
          • mexico
          That file did work for my computer
          • mikeybass
            by mikeybass
            04-23-2025, 04:30 PM
          • akwky
            by akwky
            Hi!
            04-14-2025, 01:56 PM
          • al3m0di
            Update bios EFCN58WW to EFCN59WW
            by al3m0di
            Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
            I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
            The BIOS version is EFCN58WW.
            When I turn on the device, it displays the message:
            "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
            The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
            I've tried
            07-29-2024, 10:32 AM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
          • 0xx
            2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
            by 0xx
            Hi folks,
            My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
            What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
            I assumed that Windows Update was interrupted due to closing...
            09-14-2025, 03:46 PM
