Hp EliteDesk 705 G4 SFF bios required.
  • ASB
    • Dec 2020
    • 142
    • Pakistan
    I downloaded and extracted the firmware pack from Hp but there are 3 bin files for different ROM families (don't know which one to use) plus their size is bigger than 16 MB which I can't edit.
  • hardware1
    • Sep 2021
    • 2957
    • N/A
    Re: Hp EliteDesk 705 G4 SFF bios required.
    (Q16) is the right one. You must delete the extra data (In the Beginning & in the End), then move your DMI.
    The attached file is ready now for flashing.
    Serial Number: MXL92258DD.
    • ASB
      • Dec 2020
      • 142
      • Pakistan
      Thank u so much Hardware1, it worked perfectly.
      • hardware1
        • Sep 2021
        • 2957
        • N/A
        It's good to know, You're Welcome.
        • abik21
          • Mar 2023
          • 6
          • pakistan
          i have also this pc and my motherboard is brick plz tell me which program software you use and i have ch341A it is ok to use this ?,plz briefly explain your method for me
          • ASB
            • Dec 2020
            • 142
            • Pakistan
            There are 2 16mb bios ics (25Q128) in ur motherboard. Look for the main bios ic and take it out. Read and save ur original bios using CH341A. If ROM family of ur bios is Q16 then download and extract the bios in post#2 for reprogramming.
            • abik21
              • Mar 2023
              • 6
              • pakistan
              i reprogram it but pc fan not turning on, i use NeoProgrammer V2.2.0.8
              erase and write
              • Effgen
                • Kazakhstan
                Hello! I also have a problem with the same PC. Please help me solve the problem too.
                I bought a new Radeon RX6400 graphics card to replace the stock R7 430. I chose this card because it is low profile, low power (R7 430 - 50W, RX6400 - 55W). After installation, the PC could not turn on. The power LED lights up for a few seconds and turns off. And it repeats itself all the time. I installed a stock video card, the PC booted up as always. Installed the RX6400 - reboots again. Then I reset the Bios settings. After that, the PC began to signal an error with a power indicator - 3 long red flashes, 3 short white flashes. I installed a stock video card, the situation is the same. I checked the R7 430 and RX6400 on another computer - they work fine. But my computer doesn't work with any of the cards anymore. I tried resetting the Bios settings again, but the situation does not change.
                I read the Bios firmware - I have Q19 (attached the saved firmware and the corrected Q19 firmware from the website). I tried to flash Q19 with firmware from the official website - the PC does not start. The power indicator is white. I flashed the saved firmware - it still won't start, the power indicator is white.
                I bought a new Bios chip and flashed it - the PC does not start. I have no idea how to fix it anymore.​
              • Effgen
                • Kazakhstan
                HP Elitedesk 705 G4 SFF. Ryzen 7 pro 2700.
                Product number: TZW28EA#ACB
                Serial number: CZC944CPJJ
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12710
                  HP EliteDesk 705 G4 Small Form Factor PC_Q19
                  If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                  Subscribe to support us. It only takes 1 minute:
                  https://www.badcaps.net/settings/subscriptions
                  • Effgen
                    • Kazakhstan
                    Thank you, kind man!
                    Everything is back to its original state - with any video card, the PC issues a graphics core error (three red long flashes and three white short flashes). I will continue to search for information about the malfunction. Thanks!​
                    • 8npgXc
                      • Apr 2024
                      • N/A
                      Hello, could you please help me? I also have HP Elitedesk 705 G4 SFF. The bios can't work, I downloaded and extracted the firmware pack from Hp but there are 3 bin files for different ROM families, I don't know which is the right one...
                      The file size is bigger than 16 MB which I can't edit.
                      Product number: 6CS09EC#AB2
                      Serial number: 4CV9308Q1L
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12710
                        Missing a backup bios file.
                        • 8npgXc
                          • Apr 2024
                          • N/A
                          i missed the bios file....really thanks
                          • AlexPas
                            • Dec 2024
                            • 7
                            • Greece
                            Hello I have a problem with Hp Elitedesk 705 G4. I try to start the pc and it didn't post or boot anything and the fans were working in full speed. So after some CPU, fans , ram , ssd tests I suspect a corrupted bios.
                            I manage to read and save the stock file from the MX25L12873F chip, with ch314a. But now I can't program and update the chip because the file is slightly larger and also it doesn't contain the pc information (name, s/n etc).
                            Pc details:
                            Name: HP Elitedesk 705 G4 MT. Ryzen 5 2400g.
                            Product number: 3AB55AV
                            Serial number: CZC932CMJD
                            I provide you the backup file from bios read and the 3 files from the sp155445.exe (bios file that HP gives for my serial number). With the HxD I found the Q06 reference in hex, maybe that helps.
                            Can you help me to get a right bios file for programming ?​
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12710
                              Pc details:
                              Read the chip again, it's not good.
                              • AlexPas
                                • Dec 2024
                                • 7
                                • Greece
                                Unfortunately this is the only thing that I get. I am uploading also from AsProgrammer V2.1.0.13 but I thing there is the same problem.
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12710
                                  Actually your first file is better but the DMI area is still not ok.
                                  • AlexPas
                                    • Dec 2024
                                    • 7
                                    • Greece
                                    Is there any other way to fix it or to corrected ? Hp EliteDesk 705 G4 SFF file is totally different can we use it as dump ?
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12710
                                      Okay. Learn more about BCU to restore DMI.
                                      Description : HP EliteDesk 705 G4 MT
                                      Serial Number : CZC932CMJD
                                      Product Number : 3AB55AV
                                      BID: 18WWF7FT6**#SABU#DABU
                                      FEATUREBYTE : 3E3X 475K 6J6S 6b7B 7H7M 7Q7T 7W7m aBapaqau bhcA dUdp dqhK hZjh .Rr
                                      • intelg
                                        HP Elitedesk 800 G6 lost BIOS admin password
                                        by intelg
                                        Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                        Here is the hardware identification specs:
                                        HP EliteDesk 800 G6 Desktop Mini PC
                                        Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                        BIOS ver S21 Ver. 02.05.01 01/05/2021
                                        Born on date: 07/26/2021
                                        SN MXL11841GN
                                        SKU 3X8V9UCHABA
                                        UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                        SYSTEM BOARD ID 8710
                                        SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                        11-03-2023, 02:05 AM
                                      • Berun
                                        HP EliteDesk 800 G6 mini - BIOS Chip (GD25B127DSIG) replacement after epic fail :D
                                        by Berun
                                        Hello All,
                                        I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
                                        I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
                                        I read the Chip on board 8 times (with power...
                                        04-09-2026, 06:24 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • BrentH561
                                        Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
                                        by BrentH561
                                        Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
                                        HP EliteDesk 800 G6 SFF
                                        Serial No: MXL1223499
                                        Product No: 26S74UT#ABA
                                        BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
                                        08-23-2024, 08:36 AM
                                      • Trademark
                                        Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                                        by Trademark
                                        I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                                        This is NOT a BIOS password removal request.
                                        I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                                        Laptop Information
                                        • Model: Acer Predator Triton 16 PT16-51-99GL
                                        • Motherboard: DA0ZQDMB8AE Rev. E
                                        • Main SPI flash: Winbond W25Q256JVEN (32MB)
                                        • Secondary
                                        07-22-2026, 08:57 AM
