Thank you.
Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Hp EliteDesk 705 G4 SFF bios required.
Hello again. Can you check if that file bin file (final_G5_MT_with_details.BIN) is ok for bios installing. I add also my original corrupted one (corrupt_G5_MT.bin).
Thank you.- Description: HP EliteDesk 705 G4 MT
- Serial Number: CZC932CMJD
- Product Number: 3AB55AV
- BID: 18WWF7FT6**#SABU#DABU
- Feature Byte: 3E3X 475K 6J6S 6b7B 7H7M 7Q7T 7W7m aBapaqau bhcA dUdp dqhK hZjh .Rr
Attached FilesPremium supporters get full download access and other benefits.
HP EliteDesk 705 G4 Microtower PC RCTO Base ModelHello again. Can you check if that file bin file (final_G5_MT_with_details.BIN) is ok for bios installing. I add also my original corrupted one (corrupt_G5_MT.bin).
https://www.badcaps.net/donateComment
Computer won't start. Can someone fix BIOS?
SN CZC9457HLS, HP 705 G4 SFF, PRODUCT 3AD02AVAttached FilesPremium supporters get full download access and other benefits.
I apologize profusely. I mistakenly selected a different BIOS. That one comes from a motherboard where the bridge is damaged.Attached FilesPremium supporters get full download access and other benefits.
HP EliteDesk 705 G4 Base Model Small Form Factor PC
Hello, could you please help me with the BIOS for an HP EliteDesk 705 G4 MT. The only light on the computer is red and the fans are spinning. I noticed it has three chips identical to the BIOS, but only one is labeled as BIOS on the motherboardAttached FilesPremium supporters get full download access and other benefits.
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
Hi. Could you help with the bios?
HP 705 G4 SFF
PRODUCT 6ZU04UC#ABA
SN MXL92644YVAttached FilesPremium supporters get full download access and other benefits.
UnlockedAttached FilesPremium supporters get full download access and other benefits.
HELLO
I NEED ELITEDESK 705 G4 65W
Post the serial number - https://www.badcaps.net/forum/troubl...18#post3666218 and explain what the problem is..Comment
SN:MXL9332RZG
PN:3AE45AV
PROBLEM:NO DISPLAYComment
Hello Could someone help me please? I've tried to update my BIOS on HP EliteDesk 705 G4 Small Form Factor with the programmer CH341A and AsProgrammer utility. I downloaded BIOS from HP site but realised that size of those BIOS is bigger only when program sad "BIOS file is bigger than flash". Before that I did a dump, so I've tried to flash it back but system won't start with post code signals that BIOS is incorrect (2 long signals with white led and 4 short signals with the red one). What I did wrong? What should I do now? Can somebody help me to fix it?
Serial № MXL9263WT6
Product № 6ZU04UC#ABAAttached FilesPremium supporters get full download access and other benefits.
HP Elite desk 705 G4 MT.
Product number: 6RX05US
Serial number: MXL9283DQG
Bios q09 version.
Powers on.no display.kindly repair my attached bios thank youAttached FilesPremium supporters get full download access and other benefits.
by intelgHello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
Here is the hardware identification specs:
HP EliteDesk 800 G6 Desktop Mini PC
Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
BIOS ver S21 Ver. 02.05.01 01/05/2021
Born on date: 07/26/2021
SN MXL11841GN
SKU 3X8V9UCHABA
UUID 8116E79EF6FFE94DB0B98A3188270C5C
SYSTEM BOARD ID 8710
SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...-
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by BrentH561Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
HP EliteDesk 800 G6 SFF
Serial No: MXL1223499
Product No: 26S74UT#ABA
BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most...-
Hello guys,
I stupidly tried to read out my BIOS & EC flash (with a clamp). This didn't work, I only read FF's. But after this operation, the PC is not longer turning on, just beeps 5 times (and blinks red) then 2 times (blinks white). The manual says this is the error code for: "The embedded controller cannot find valid firmware.".
I think it locked itself because of my experiment. Is this fixable? I now removed both chips from the board and dumped them, I attach the files in this post hoping someone can help me fix my stupid error. Thanks so much in advance anyone...-
by brispussPurchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),... - Loading...
