Password bios Dell Optiplex 5090
Every donation made will go towards server fees and maintenance costs. -
I Have 2 5090 optiplex's that have the Bios admin locked, both on 8FC8 Bios, i have a ch341a but only with a 8 pin clip, have ordered a 16pin clip, the chip on the motherboard is a Winbond 25R256JVFN, would i need to modify the 16pin clip one i get it, or will it work with no modification? i have the v1.7 of the ch341 with voltage adjustment.
ThanksComment
Badcaps Giants,I Have 2 5090 optiplex's that have the Bios admin locked, both on 8FC8 Bios, i have a ch341a but only with a 8 pin clip, have ordered a 16pin clip, the chip on the motherboard is a Winbond 25R256JVFN, would i need to modify the 16pin clip one i get it, or will it work with no modification? i have the v1.7 of the ch341 with voltage adjustment.
Service tag 8R1FNM3-8FC8 Optiplex 5090 SFF
Need some help,
Managed to read the 25R256JVFN bios chip, took 2 copies, made the modification of searching for "00 FC AA" and replacing it with "00 FC 00" ( nothing came up on this one ), then the same for "00 FD AA" and replacing it with "00 FD 00" had 2 entries. Erased the chip and wrote the modified bios file to the IC, pc would not boot at all, only orange power light came on and off.
Erased the bios again and wrote the original copy, still would not boot, any ideas?
Both files attached
Any help appreciated, Thanks
Attached Filesif you find these attachements useful please consider making a small donation to the site
You failed because the backup failed.
Badcaps Giants,
Need some help,
Both files attached
Any help appreciated, Thanks↵
https://www.badcaps.net/donateComment
hi plz unlock admin password bios dell 5090 optiplex microAttached Filesif you find these attachements useful please consider making a small donation to the site
Type theservice tag, full name and model, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
1st boot, press F2, write service tag, disable Absolute, save, restart.
2nd boot press Alt+F to exit manufacturing mode.
Good luck.Attached Filesif you find these attachements useful please consider making a small donation to the site
PEZ SIR HELP ME TO REMOVE PASSWORD SETUP
DELL OPTIPLEX TOWER 5090
SERVICE TAG (DS14QP3)Attached Filesif you find these attachements useful please consider making a small donation to the site
3.4. Dell
Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
Note: There is no publicly available 8FC8 generator available at the moment.
The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher↵
Hello, please help unlock the BIOS for Dell Micro 5090. During the process of reading BIOS, it got corrupted. The ME and GBE are no longer correct. I accidentally deleted the original BIOS so no chance to reading again. I am sending the corrupted BIOS file. The service tag is 4GVBKQ3. Thank a lot.Attached Filesif you find these attachements useful please consider making a small donation to the site
TryHello, please help unlock the BIOS for Dell Micro 5090. During the process of reading BIOS, it got corrupted. The ME and GBE are no longer correct. I accidentally deleted the original BIOS so no chance to reading again. I am sending the corrupted BIOS file. The service tag is 4GVBKQ3. Thank a lot.Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
Hello I have a dell optiplex SFF plus 7020 with a password that I recovered from e-waste. It is possible to get the password removed via the bios patch method? I managed to dump the 32MB bios chips and would like help patching it to MFG mode so I can clear the password.
Thanks.
1hj4z24 = Service tag
A schematic would also be amazing if anyone has one!...-
by CuteWildCatHello there,
My Dell Optiplex 3090 bios is locked with admin password. Worst of all, it seems.
Here is my system number 1THQMS3-8FC8.
I don't have the hardware to dump my bios, and I can't pay 400€ to hope to get a password from a guy I don't even know exists. So without conviction I'm wondering if anyone here can help me.
Thank you in advance...-
by lamtran20Serial Number: BBTSQ53
Dell Optiplex 7480 AIO. It is bios locked, any help removing the password would be greatly appreciated....-
- Loading...
