XPS 2720 - Can anyone extract a ROM file from this executable?
  • wibble
    • Jan 2011
    • 31
    Hi fellow BIOS modders
    I have a Dell all-in-one 2720 computer. The error is a bit weird, whatever you do it just beeps four times with no display on start up.
    Inside the machine, it's a Pegatron IPPLP motherboard and I believe it uses an AMI BIOS, rather than a specific Dell BIOS.
    I removed the BIOS chip (Winbond 25Q64) and was able to read the chip from my programmer. However, I do not have the original BIOS ROM file to compare it against.
    I have attached a zipped file containing the Dell update utility with the latest BIOS (A13). This file can also be downloaded from Dell at
    https://www.dell.com/support/home/en...driverid=8d33g
    If anyone can extract the ROM file (8MB) from the package I would be very interested . . . I have tried Dell PFS Extractor and some AMI BIOS extractors but got no joy, maybe I am doing something wrong.?
    Much obliged, thank you in advance
  • wibble
    • Jan 2011
    • 31
    Re: Can anyone extract a ROM file from this executable?
    Attachment of BIOS update executable
    • wibble
      • Jan 2011
      • 31
      Re: XPS 2720 - Can anyone extract a ROM file from this executable?
      does anyone have a valid bios rom image for this machine
      • wibble
        • Jan 2011
        • 31
        .anybody...
        • hoaca388
          Badcaps
          • Jan 2022
          • 12322
          This is not a complete bios file, it only has the bios region part, the device's original bios file is required for incorporation.
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
          • Jk KIM
            Lenovo Ideapad 5 15ITL05 Bios File extract
            by Jk KIM
            Hi
            I need to extract bin file from bios update file which downloaded at Lenovo web site.
            Pls extract bin file from exe file...
            I attached exe file!
            Thx!...
            02-03-2023, 07:40 AM
