High side mosfet of the power supply of the RTX2060 graphic chip burned out
  • zwerw3
    • Jan 2021
    • 12
    • Казахстан
    Hello. They brought a personal computer for repair in which the video card was GeForce RTX ™ 2060 WINDFORCE OC 6G (rev. 1.0). Graphics core power mosfet burned out.
    Is there a chance to restore the site where the mosfet was? I started to grind the mosfet substrate with a dremel, which stuck to the board, but for now I stopped and decided to ask you for advice. I also noticed dark spots on the PCB near the video memory chips. Does this mean that the video memory is out of order? I cleaned the place where there was a burnout, a short circuit of 12 V was removed. On the coils on the power supply of the chip 1 ohm, on the power supply of the memory 36 ohms. Are these resistances normal? I have not encountered video cards, so I ask you for help.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: High side mosfet of the power supply of the RTX2060 graphic chip burned out
    as u see u have MANY free phases. just move mosfets and few components to free phase
    just grind until u dont have short on main 12V phase
    • zwerw3
      • Jan 2021
      • 12
      • Казахстан
      Thanks! I'm trying to do it. I will write the result of the work.
        by sam_sam_sam
        03-31-2024, 02:12 PM
      • Wolf1977
        general question when a mosfet on primary of transformer is burned
        by Wolf1977
        hi
        in a welding machine i had a mosfet and four components wich connect with it burned
        i ordered all the damaged components and replace it but when i put the device on the plug all the components burned again i had tested before and i had not shunts
        i dont understand whats happen wrong
        more particular on the schematic q11p01 mosfet q11p02 tranzistor
        three paralel resistors had burned q11p07 zener shunt q11p08 open
        when i changed all these shunts q11po7 mosfet and tranzistors
        maby the transformer has problem on your opinion or something on...
        08-19-2023, 01:27 PM
      • Mike_Ho
        Any Idea for repair L13 Gen2 LAR-2 PD Charger Mosfet CSD87501L always Burned
        by Mike_Ho
        Dear All
        Anybody have experience to repair L13 Gen2 Board Number : LAR-2 PD charger problem?
        I have one board the U4201 CSD87501L are burned and the 20V_VBUS_USB2 can't switch to 20V_VINT_IN, after replace this Mosfet it's still very HOT and just use few hours will burned again. i have repeat replace this Mosfet 3 times and all dead.
        After that i try to shorted Mosfet Source 1 to Source 2 to bypass the 20V, and found the Control Gate 1 and Gate 2 voltage both are 20v same with 20V_VBUS_USB2.🤨
        So did anybody know this case will need to replace...
        03-15-2024, 02:02 AM
      • Acnologia
        How to diagnose mosfet with lab-supply ?
        by Acnologia
        Hello to everyone ,
        So far most of the repairs that i've been doing was novice, i would say. With a lot of help from you gents.
        Now ,i got in my hands a lab-supply. So , i have a laptop in my hands that doesn't turn on , remains dead , but at the same time there is no short circuit in the main line (as i think off).
        I know that i should put 1v-2v to ground (black wire) and red wire to close the circuit to a specific place after the DC-IN port.
        Now the question is, where do you place it most of the time , i mean in which specific place after the power...
        09-14-2025, 06:35 AM
