Need help fault tracing RX580 GPU
  • survivalbloke
    • Aug 2021
    • 307
    Hey!
    I'm working on a Sapphire RX580 Pulse graphics card which has no power. As shown in the picture, the two main B+ fuses are both open. If I measure from the bottom end of the fuses to ground, I get 1.3ohms, which I *think* means I'm reading resistance of the GPU - I'm still very much learning. Ground to output side of Vcore coils shows the same, 1.3ohms. If I inject 1v 2a into the bottom of the fuse, I'm sinking almost the entire 2a into the GPU which is the only visible component on a my thermal camera.
    I'm not sure where to go here. I'm tempted to just pull the driver to see if the short goes away but before I do that, I wanted to check in here to make sure I'm not chasing my tail.
    https://imgur.com/L7xBpkl
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Need help fault tracing RX580 GPU
    1.3ohm mean u have shorted power stage/mosfet,optimos,.../
    • survivalbloke
      • Aug 2021
      • 307
      Yeah, but I'm wondering, how can I tell if it's one of the power stages or the driver chip? Also, what's a optimos?
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • Sik_6ty_Sixx
        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
        by Sik_6ty_Sixx
        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
        02-18-2025, 05:06 AM
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
      • howardc64
        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
        by howardc64
        • Prior owner tried a replacement main board. No difference.
        • Samsung 2x red blinking standby LED = panel fault
        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
        07-19-2025, 10:54 PM
        ESR meter came to the rescue again today with a PLC I/O card fault
        I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
        I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
        One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
        12-18-2023, 08:17 PM
