help with gteway gt4016 caps
  • djdaredevil
    • Aug 2010
    • 5
    i have a customers gateway that i have already diagnosed to a bad cap the problem is i cant figure out what kind or ratings it is.
    its about 6-7mm high and 10mm around they are aluminum with just a little part on the top thats black the only markings on it are not that clear but it looks like it says 50 (or 5D)
    680
    4J the j is really small print
    i would really appreciate the help
  • djdaredevil
    • Aug 2010
    • 5
    Re: help with gteway gt4016 caps
    couldnt find the edit button but i stare at this thing under a magnifying glass and the j (4j) could be a v if you rotate the cap a little
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      680uF 4v but that's all I can tell you.
      Mann-Made Global Warming.
      - Dr Seuss
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        https://www.badcaps.net/store/produc...products_id=79
        • djdaredevil
          • Aug 2010
          • 5
          thanks for the help guys i just have never had to change one of the solid aluminum ones before so i didnt know which ones to get.
          really glad you guys could help me
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Solid caps don't normally need replaced.
            Why do you think you need to?
            - Dr Seuss
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              those are lytics and are often blown.
              the replacements i linked to are polys and are what i use.
              • djdaredevil
                • Aug 2010
                • 5
                they look just like solids but they had vents in the top and one was leaking so im going to replace all the ones on that line
                can i replace the lytics with solids cause thats what i ordered found some of the exact same values
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  All of Solids, Hybrids, and Lytics come with or without the plastic sleeve.
                  The printed sleeve -vs- bare with ink/paint is just how they are marked.
                  It has no bearing on the kind of cap they are.
                  Vent = Traditional Wet Electrolytic or Hybrid Polymer. [Hybrid sometimes aka 'Functional']
                  True Solid Polymer don't have vents.
                  Hybrid Polymer might have vents if over 6mm diameter. [Some do, some don't]
                  Wet Electrolytic do have vents if 8mm or larger diameter, and might if smaller.
                  I'm pretty sure Fujitsu was the first to make Hybrids.
                  Before 8-10 years ago the Fujitsu Hybrids *occasionally had problems with moisture leaking IN, but seals were improved and Hybrids are now as good as Solid caps. Most people consider them the same as Solid caps because their is no performance of longevity difference. - [Nichicon markets some caps as Solid Polymer and others as Functional[Hybrid] Polymer [FPCAP] so their is some construction/design difference but nothing that matters.]
                  ~~ All of that is just to explain what is going on when you see someone call a cap with a vent a Solid Polymer. Either the person is confused or it's a Hybrid cap.
                  >> can i replace the lytics with solids.
                  I can't say without a photo of the board, but kc8 has seen that board and he linked you to solid polys as replacements so I'd have to say solid polys [or hybrid] are just fine.
                  You should replace ALL of them. [That brand.]
                  - Not just the bloated ones.
                  If some bloated the rest aren't far behind.
                  - Dr Seuss
                  • djdaredevil
                    • Aug 2010
                    • 5
                    i could only get 6 and the board has ten so i was just going to replace the ones on that line or whatever it maybe called they have numbers printed on the board next to them so i was going to replace the ones with the same number until i can get more of them
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
