PS_NVVDD_EN_R low - circuit question
  • Prott
    • May 2022
    • 154
    • Czechia
    I have a possibly stupid question which I am, unfortunately, already trying to figure out for some time.
    I have a card (reference 1080Ti) that has PS_NVVDD_EN present (3v) while PS_NVVDD_EN_R is low. The schematics doesn't quite make sense to me as both of the resistors that are connecting PS_NVVDD_EN_R line to 1V8 and PS_NVVDD_EN are omitted (R536 and R535).
    And now the stupid part - which component is responsible for pulling the PS_NVVDD_EN_R line high?
    Thank you.
  • Prott
    • May 2022
    • 154
    • Czechia
    Re: PS_NVVDD_EN_R low - circuit question
    Schematic in question - there's no other connection except those two mosfets. Is there a way the rail is getting powered from EN_Q through them?
    My understanding is that once PS_NVVDD_EN is high the first mosfets pulls EN_Q low which then in turn shuts off the other mosfet and enables EN_R to go high (leaves it floating) - EN_R itself needs to be pulled high from something else somewhere. Is this incorrect?
    Thank you.
    • piernov
      • Jan 2016
      • 4439
      • France
      Reading the datasheet of the buck controller (uP9511?) can help. EN is not pulled-up externally, external circuit leaves it floating to enable or pulls it to ground to disable. Since there's a resistor to ground which must be inside of a certain range of value, one can assume the chip has an internal current source on that pin, although it may not be active all the time.
      • Prott
        • May 2022
        • 154
        • Czechia
        Thank you! I was reading the datasheet, but somehow skipped the part and it didn't occur to me that the buck controller produces its own enable signal.
        Time to check the soldering.
        • Prott
          • May 2022
          • 154
          • Czechia
          Fixed (it was a bad soldering job on the buck controller), thank you piernov!
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • Tarot Superstars
            Short Circuit tester
            by Tarot Superstars
            Hello.
            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
            Link
            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
            https://www.youtube.com/watch?v=0eixDdCpiO4
            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
            09-25-2023, 09:11 AM
          • Alimash
            op amp circuit function?
            by Alimash
            I am repairing a ups which doesn't turn on ,it has the following ICs:
            SG3525 used to drive inverter mosfets.
            couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
            A LM358 and TL074 for control mechanism and of course the uController.
            The SG3525 is shutting down every time the ups is turned on.
            I want your help to know the function of LM358 and TL074 in the system.
            I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
            07-31-2025, 07:45 AM
          • M1NEBLANK SHOW
            MSI B250 Gaming M3 Short circuit in CPU power supply circuit
            by M1NEBLANK SHOW
            Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
            (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
            Schematic and Boardview here
            04-04-2025, 03:57 PM
          • karatzdi
            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
            by karatzdi
            I know some might say... just buy another one. Sell it as parts..!
            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
            Spent some time downloading the Service...
            06-11-2024, 08:38 AM
