Advantech DAC-BC05 Power problem
This topic has been answered.
  • andrestecno
    • Jul 2022
    • 24
    • Argentina
    This small motherboard does not turn on, I have measured the outputs of the sources and most of them seem to work except 2, one is from the Q5 and the other from the U6(Isl6537acrz), which apparently could be the problem since the 12v does not reach it. They go through R257. Looking at U6 it seems burnt, what could be the reason? What do you think ?
  • Answer selected by andrestecno at 07-18-2024, 07:12 PM.
    mon2
    • Dec 2019
    • 13999
    Re: Advantech DAC-BC05 Power problem
    My suspicion will be with the RAM.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Welcome to Badcaps!
      It let out the magic smoke, electronics don't work when the magic smoke escapes
      Seriously though it is hard to tell, but a guess could be one of the black tantalum caps is shorted, or one of the mosfets.
      It is unlikely that just the IC burns up without some external reason like listed above...
      • andrestecno
        • Jul 2022
        • 24
        • Argentina
        Re: Advantech DAC-BC05 Power problem Updated
        I replaced the Isl6537acrz and the R257 and now it turns on and works. There is a problem when starting, colored dotted lines appear and last a while until they disappear. Anyone know what can it be ? attached video.
        • mon2
          • Dec 2019
          • 13999
          • alejandro22
            • Mar 2020
            • Argentina
            I have the same problem, in q5 I have no voltage, I changed the double mosfet, and it starts but I notice that the mosfet heats up a lot
            • mon2
              • Dec 2019
              • 13999
              If the mosfet heats up, remove all power -> measure the resistance to ground on each pin of this mosfet. Someone is placing a heavy load on the mosfet to raise the temperature through a low resistance.
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Duranitron
                Asus x512dk rev 2.1 power on problem
                by Duranitron
                When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                11-26-2024, 10:22 PM
              • EazyBone
                LG OLED55C9PUA power problem
                by EazyBone
                Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                The power supply to t con is different story.
                This...
                06-23-2023, 07:43 AM
              • Dr.d
                Help please..Lenovo ideapad 5 14itl05 power and charging problem
                by Dr.d
                I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                04-05-2024, 11:48 AM
                by sam_sam_sam
                03-31-2024, 02:12 PM
