Shorting Motherboard PWR Pins Does Nothing
  • SashaG
    • Feb 2022
    • 11
    • Philippines
    This is a bench test so I've tried booting without components (No SSD, No GPU, With/Without RAM, With/Without CPU). I only have the CPU Fan plugged in and Buzzers.
    PSU is all good. 5VSB present, standby LEDS light up. No shorted MOSFETS on CPU. I know there has to be a short somewhere. Anyone has an idea where to start looking? Thanks!
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    Re: Shorting Motherboard PWR Pins Does Nothing
    Sounds a bit funny but I'd try shorting the green and black wire. I had a semi-dead ASUS P5ND2 boot that way.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
      • 21869
      It might help if you posted the motherboard model number
      • MasterCap
        • Jul 2022
        • 37
        Probably not the same thing at all, but I have a new z690 mobo, and it does not always respond to the PWR button when trying to turn on. Somehow the BIOS chooses to ignore it.
        I don't think in the old days, a BIOS would ever ignore the turn on signal, maybe it's a windows thing, and I wish they'd leave the BIOS alone.
        • araxnido
          Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
          by araxnido
          Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
          When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
          06-10-2025, 09:26 PM
        • glovecaps
          by glovecaps
          11-25-2024, 04:23 PM
        • Docus
          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
          by Docus
          Hi everyone 😀,
          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
          1. I already own the exact same model, but its plastic chassis is badly damaged.
          06-10-2025, 04:24 PM
        • Archimedes
          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
          by Archimedes
          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
          Fans are spinning. Blindly could install windows11 and got the device manager...
          07-30-2024, 05:14 PM
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
