Intel D865GLC desktop board. no power-on without cards installed
  • charlyd
    • Feb 2013
    • 7
    • nl
    Hello i have 2 D865GLC boards which i tested on my bench,
    but on YouTube and the web i find movie where this board is started in native setup (just cpu.mem,psu)
    connected to the onboard.
    on both my boards i need to install a pci card otherwise the cpu fans will stop af 2 seconds spinning.
    all my caps look ok, and both boards don t give
    any error or other (boot) problem, but only with a pci card installed.
    what are my boards different from other boards??
    curious to responses..
    thanks
  • charlyd
    • Feb 2013
    • 7
    • nl
    Re: Intel D865GLC desktop board. no power-on without cards installed
    does this problem has todo with motherboard caps?
    despite that the board boot ok without problem into windows with a pci card installed?
    but with no card cpu spins shortly and that is where the process ends. no post , no picture , no poweron
    Who has seen this behaviour more?
      • 21847
      what sort of PCI card do you mean, a graphics card
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yes, see more here: https://www.eevblog.com/forum/repair...-av-bios-file/
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Seems to possibly be a BIOS issue, are you running the latest BIOS?
          I attached the full BIOS changelog for all BIOS versions up to the latest P25.
          BIOS Version P13-0053 (Production 13, build 0053):
          Fixed issue where system would not complete POST if no videocard is plugged in and a LAN card present.
            • 21847
            I read it then got sidetracked looking at used scopes on ebay
              • 21847
              Does all the old scopes with standard retail motherboards have a customised bios
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Yes this is the danger of browsing eevblog too much, wait till you get drawn into the TEA thread!!!
                No, most just use a custom splash screen and that's it, see an example here:
                https://www.eevblog.com/forum/repair...oscope-repair/
                • charlyd
                  • Feb 2013
                  • 7
                  • nl
                  @SMDflea, yes i installed a S3 trio card but i also get a picture on the onboard vga connector. But it just will not poweron without cards installed ? cpu fan en psu fan spin for 2 seconds and them nothing...
                  • charlyd
                    • Feb 2013
                    • 7
                    • nl
                    Hi Per Hansson, you are right it is probibly not the bios i have to rectify on evvblog. the Bios give the different splash.
                    the most weird thing i have is the same behaviour on two boards. both not coming to live without a card. And With card they work fine. when bios is set to agp the onboard give a picture. (but S3 trio installed) when set to PCI the post screen show on pci card. tested all things like installing windows on a conneted drive all work great but really weird "that must have card"
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Did you even read post #5?
                      https://www.badcaps.net/forum/showpo...39&postcount=5
                      • charlyd
                        • Feb 2013
                        • 7
                        • nl
                        @Per hansson: you mean the issues written in the P25 new fixes/features.
                        ew Fixes/Features:
                         Updated VBios to Build 1235.
                         Fixed and issue of not defaulting video to the proprietary video card.
                         Fixed and issue of POST code D0 hang when proprietary video card is installed and
                        CMOS is corrupt.
                        yes yes i have seen them but the bios version of demindragon his board was P17. and working ok.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          No, version P13 as I quoted in post #5
                          • charlyd
                            • Feb 2013
                            • 7
                            • nl
                            now i have read all onder bios issues 1 by 1. indead there was an issue... i gues fixed in the newer version. mine was P22. but i even saw video issues fixed in P25.
                            so will flash to that one later..
