Ch341a programmer problem
  • sasalli
    • Oct 2016
    • 22
    • Turkiye
    Hi to all!
    i have ch341a programmer. iam trying to program MX25L6475EM2I-10G chip with 16mb file, bu the programmer software(v1.18) says ''FILE LENGHT, BEYOND RANGE OR IT WILL BE IGNORED''. What should i do? Thanks!
    • 31102
    Re: Ch341a programmer problem
    what is the file size?
    • Zsombi114
      • Apr 2022
      • 23
      • Romania
      Try to use another program.
      • Zsombi114
        • Apr 2022
        • 23
        • Romania
        Asprogrammer, CH341A programmer, Neoprogrammer etc.
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          • Romania
          Would recommend Colibri as well, usually works great with those CH341A programmers.
          Main rig:
          Gigabyte B75M-D3H
          Core i5-3470 3.60GHz
          16GB DDR3-1600
          Samsung SH-224AB DVD-RW
          Delux MG760 case
          • ductranvinh
            • Dec 2021
            • 133
            • Republic of Vietnam
            u need asprogrammer yet ?
            PC work for schemaltic:
            Mainboard: Gigabyte Z68XP-UD4
            CPU: I3-3240
            Ram: 16Gb
            Graphic Card: GTX 1050Ti zotac 4Gb Mini
            SSD: 120Gb
            HDD: 2Tb
            • anikin73
              • Mar 2022
              • 112
              • singapore
              I think your bios file need to be edited. Can you share what file / bios u trying ?
              bios from offical website may need editing
              • sasalli
                • Oct 2016
                • 22
                • Turkiye
                NeoProgrammer says "Buffer size not equal to IC size"
                file is 16,0 MB (16.777.216 bytes), here;
                https://www.badcaps.net/forum/showpo...76&postcount=4
                what do you suggest?
                • peste
                  • Dec 2016
                  • 13041
                  • ROMANIA
                  try this program too ..
                  https://www.badcaps.net/forum/showpo...6&postcount=10
                    • 21280
                    What size is the bios chip you`re writing to, the LMQ-1 MB has two different bios versions, 8MB and 16MB ,depending on the X1 Model Type .
                    https://www.badcaps.net/forum/showth...hlight=12298-2
                    • lotas
                      • Jan 2016
                      • 4673
                      • Russia
                      To write a 16Mb file, you must have SPI Flash 25x(128) and your flash is only 8Mb wide.
                      • sasalli
                        • Oct 2016
                        • 22
                        • Turkiye
                        @peste;
                        AsProgrammer says "File size larger than IC size"
                        @SMDFlea;
                        Lmq-1 mb 12298-2
                        48.4ly06.021
                        @lotas;
                        MX25L6475EM2I-10G
                        how did you know its size?
                        • lotas
                          • Jan 2016
                          • 4673
                          • Russia
                          64 Mb bits = 8 Megabyte (Mb).
                          • sasalli
                            • Oct 2016
                            • 22
                            • Turkiye
                            Now the situation is clear. So i need MX25L12872FM2I-10G than? Thanks to all!
                            • lotas
                              • Jan 2016
                              • 4673
                              • Russia
                              Yes, you can use any for 128, MX25L12835FM2I-10G...
                                • 21280
                                or you can flash the 8MB bios version
                                • EbrahimSiami
                                  Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                  by EbrahimSiami
                                  I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                  **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                  **What I have tried so far:**
                                  1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                  07-02-2025, 02:31 PM
                                • JoWed
                                  Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                  by JoWed
                                  Hello Community,
                                  I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                  07-01-2025, 09:32 AM
                                • lucaszmn
                                  by lucaszmn
                                  Problem:
                                  Initial Findings:
                                  • I concluded that the
                                  08-12-2025, 03:01 PM
                                • ademturk
                                  optiplex 7010 micro plus
                                  by ademturk
                                  i think i really stuffed it i dont have backup of original bios iam trying to connect this ch341a for a few weeks now just yesterday i managed to find my problem all this time the green board between the wire and dongle was on the wrong way. ive downloaded the BIOS_IMG_rcv file renamed rcv to bin but the programmer says its too big also tech friend had a look at it and said it was bios was security protected. ive used imsprog and flashrom from linux and from windows i have tried neoprogrammer asprogrammer and original ch341a programmer. also the main reason i had trouble connecting was the...
                                  06-23-2025, 04:21 PM
                                • testaccgta
                                  Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                  by testaccgta
                                  Hi, everyone!
                                  I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                  I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                  09-01-2024, 08:24 PM
