Can use some help with this board. I am new to diagnosing. This is a Powercolor red devil rx5700xt. Gpu gives a code 43 in device manager. No display. Have multiple board shorts and a hot spot which I believe to be a buck converter. Can someone please offer any assistance, I really want to learn. Thanks in advance.
Board shorts RX 5700 XT
Re: Board shorts RX 5700 XT
It seems very unlikely to me to have all those secondary VRMs shorted. In fact your ohm readings don't support that. But yes, some of those resistances seem too low.
But that does not seem to be the main issue here.
Since you have all voltages on boot (you did not clarify whether the card has picture): as soon as you have some load on the card, it gives up.
To my understanding, those type of cards don't use al VCore VRMs all the time. It may only use a few at boot. After post it may activate other VRMs causing the card to crash.
Maybe a faulty power stage or the controller?
Where is that heatspot in the FLIR image located?Comment
So the actual heatspot is that GS9230?
Buck converters can get a little bit warmer, but it obviously did not burn. I guess it's responsible for 1.8V or PEX voltage (please correct me if I'm wrong, still learning myself). If one of those voltages drops I would imagine bringing down other voltages as well (= crashing the card).
Try taking a reading on the VOUT (https://cdn.badcaps-static.com/pdfs/...9f8d711304.pdf). Does it change at the same time as it goes black?Comment
Update. Have NO idea what I did other than check the bios and a thorough cleaning, fresh thermal paste. It fired up with no code 43. Will put it through its paces and confirm stability.
Will update again in a few days. Thanks for the help didi79 !!!Comment
So I put it in a small mining rig I have and it ran for 48 hrs just fine, then crashed. During those 48 hours I could see the bios info in hiveos, now the bios info is not present but still works. Temps are good, pulls 114 watts. When it crashes, if I reboot, it works again. Windows shows code 43 again. Ordered new bios chips, and controller chip gs9230.Comment
If i remember correctly this could be as mentioned Bios issue / boot strap resistor issue. But also faulty Vram. You could see few videos from the youtuber techcemetary. He´s the only one i know of who likes to waste time on fixing graphics cards.
Depending on my expiriance, successful GPU repair ratio is usually around 40-50% or less depending on the gpu architecture. In most cases the gpu cooling is inadequate causing thermal stress and catastrophic failures on vital parts.Comment
Thanks jonsig, I am still learning how to diagnose. I replaced both bios chips and put fresh bios’s on them. Card has had no issues, boots up every time. Replaced thermal pads and added thermal pads between back plate and pcb , temps are 26 degrees lower.Comment
AMD Radeon RX 5700 XT (RX5700XT) Schematic & Board View
The Radeon RX 5700 XT is a high-end graphics card by AMD, launched on July 7th, 2019. Built on the 7 nm process, and based on the Navi 10 graphics processor, in its Navi 10 XT variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 5700 XT. The Navi 10 graphics processor is an average sized chip with a die area of 251 mm² and 10,300 million transistors. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. AMD has paired 8 GB GDDR6 memory with the Radeon RX 5700 XT,...-
Channel: Schematics and Boardviews
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... - Loading...
