Can an iMac chime if the logic board is bad?
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Hi all.
    A friend has a 2011 iMac which chimes (and apparently plays music) but was told by a technician that the logic board needs replacing.
    The screen stays black, but music apparently plays when the keyboard 'play' button is selected.
    A bit beyond my experience...??!!??
    I was under the impression that bad logic boards don't give the Apple chime.
    Anyway, they are bringing it over tomorrow where I'll check the diagnostic LED's to get a better idea. Seems more like a PSU, GPU or inverter problem to me.
    A bad logic board should just have one LED no?
    I would love to hear your thoughts
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Re: Can an iMac chime if the logic board is bad?
    Surely if an iMac performs the startup chimes, then the logic board is receiving power and has performed the necessary basic function tests?
    That would give 'two' diagnostic LED's. My experience is limited but I have never know a 'bad' logic board to play the chimes.
    Three LED's would indicate that the GPU is also communicating fine.
    No-one out there has any experience with this?
    • reformatt
      • Feb 2020
      • 1491
      The chime means the board has completed POST and booted. So likely a display related issue. Graphics card failures are pretty common on these pre-2012 iMac's so check status LED's. Also pretty sure these displays are also fluro backlight rather than LED...can be bad cables or failed inverter but my money is on the graphics card.
      They are such a hassle to work on, and given it's age very few $$$ to be made on spending a lot of time on.
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        Hi Reformatt
        I would agree that it is most likely a GPU or even didplay issue.
        In the end I didn't get to see the iMac but thanks for the input
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ohren
          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
          by ohren
          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
          The models launched in 2018 and 2019 respectively....
          09-08-2023, 05:24 PM
        • Yanleb
          LG 60PK550 Logic Control Board EBR63450301
          by Yanleb
          Hi all, I just want to share the repair of my 60PK550-UA TV set.
          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
          C57: 3.30V
          C61:...
          07-20-2023, 12:38 AM
        • korben_dallas
          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
          by korben_dallas
          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
          MY QUESTION:
          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
          02-14-2024, 12:23 AM
