Gigabyte GA-K8NS rev. 2.0 IDE2 will not detect anything
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    As per title - and no, it is not disabled in the BIOS
    Leave CMOS battery out overnight, take defaults on boot, still doesn't detect
    Clean install of XP shows Primary and Secondary channels in Device Manager
    Board looks clean, no burnt traces anywhere that I can see
    Any suggestions ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • seanc
    • Nov 2008
    • 1319
    Re: Gigabyte GA-K8NS rev. 2.0 IDE2 will not detect anything
    Any caps next to the IDE channels?
    Is IDE2 the only thing not working?
    Have a look under the Northbridge heatsink for any damage - unlikely but possible.
    • kaniki
      • 514
      did this work one day then just not the next or did you change hardware one day when it started doing this or something else?
      The reason I ask this is because maybe the hardware might conflict with each other or if you changed something, maybe the ribbon got cut or broke in a spot or maybe the jumpers are not correct (thinking of WD hard drives on that one.. if you have a single device and set their drive to master, then it will not work. have to set it to single or set the jumper across the slave and master pins sideways.. I would love to meed the idiot that thought that was a good idea.)
      If worse came to worse, you could always get an IDE expansion card for your PCI slot if you need the extra 2 spaces..
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        IDE2 wasn't working when I got the board
        Have tried various 80-wire and 40-wire cables, and other disks
        The capacitors near the IDE connectors are all Nichicon HM - perhaps I should test them with ESR meter
        Nearly as frustrating as the Asus CUV4X-C where neither of the IDE channels work, for which I have a Promise Ultra100 controller
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          reminds me of a gx270 that came in with the same issue.
          it somehow had a sx bios flashed in it.flashed the proper bios and sec ide was back.
          and i had a 939 asus of some type that had both missing and ghost hardware.yep wrong bios!
          the p.o thought a bios flash would fix the instability from bad caps.he made a bigger mess and gave up.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            i had a 939 asus (a8n32-sli) do that too. it had the right bios, supposedly, but would not boot. now that i flashed it to the newest bios, it works great. even with a modded bios screen. maybe a bent pin on the cpu did it, thats how i got it and the cpu, among other items in the van-load, for free.
            jeez, some guys just don't understand that bad caps can't be worked around like that. the only solution for it is to get a new board or to recap it. reminds me of this thread (bad attempts at fixing bad caps):
            https://www.badcaps.net/forum/showthread.php?t=7511
            KC, i wonder if it was the same guy... gx270 both times... odd...
            sigpic
            (Insert witty quote here)
            • DynaxSC
              GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
              by DynaxSC
              I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
              General test conditions:
              - Tested with Core i5 6500 and Core I7 6700K - no difference
              - Default BIOS settings, but tried also altering several memory setting - does not change anything
              What is wrong:
              With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
              When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
              03-21-2025, 06:23 PM
              Thermal pad thickness for various laptop GPU / Graphics Cards
              ASUS Dual RTX 2070 OC 8GB
              ASUS ROG STRIX RTX 3080 OC
              ASUS ROG STRIX RTX 3090
              ASUS TUF Gaming RTX 3080 OC Edition
              ASUS TUF GTX 1660 S-O6G GAMING
              EVGA RTX 3060 Ti XC GAMING 8GB
              EVGA RTX 3060 XC GAMING 12GB GDDR6
              EVGA RTX 3080 FTW3 ULTRA GAMING
              EVGA RTX 3080 TI FTW3 ULTRA GAMING
              EVGA RTX 3090 XC3 ULTRA GAMING 24GB
              Gainward RTX 2080 Phoenix GS Specs
              Gainward RTX 3070 Phoenix 8GB
              Gainward RTX 3080 Ti Phoenix
              GIGABYTE AORUS RTX 3080 MASTER 10G
              02-09-2024, 08:08 AM
              A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
              by momaka
              More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
              And a shot of the label:...
              01-26-2022, 03:26 AM
            • iT0mT0m
              Problem with motherboard Gigabyte X570S Aero G - no detect RAM
              by iT0mT0m
              I have problem with detection RAM on this motherboard. When I install CPU(Ryzen 5 2600, 5 4500 or 5 5600G) DRAM Led is lighting all the time. I tried reflash various verion of bios using Q-Flash method and that not resolve my problem. I tried reflash bios by SVOD 4 but that not resolve problem too. All voltages is correct and I don't see any low resistance on coils and other elements on motherboard. I tried replace memory to other and nothing. I don't know where is a problem(maybe connections between cpu and rams socket?). Actually I have boardview for this motherboard and I have...
              12-23-2023, 12:17 PM
            • nikovmiroslav
              Gigabyte A5 X1 Need Bios
              by nikovmiroslav
              Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
              Gigabyte A5 X1
              From motherboard:
              S/N: 1TNH55ER1350895
              P/N: 6-77-NH55ERQY-D02-2CGB
              On sticker from the back of the laptop:
              S/N: SN21351J000657...
              08-24-2025, 09:15 AM
