gtx 285 Are this resettable fuse ok?
  • julianmustofa
    • Dec 2021
    • 39
    • indonesia
    Hi. I have problem with my graphics card.
    The dvi connector lacks of 5v power.
    I check ic and mosfet arround them no sign of faulty
    But when i check the resettable fuse have 65ohm resistance. Its mean blown ?
    And i dont know what value it is. The code “P 020”
    Btw this is an old gtx 285 cards
  • R_J
    • Jun 2012
    • 9604
    Re: gtx 285 Are this resettable fuse ok?
    Yes it is open.
    Polytronics SMD1812P020TF, 200ma hold, 400ma trip
    • julianmustofa
      • Dec 2021
      • 39
      • indonesia
      Originally posted by R_J
      Yes it is open.
      Thanks help a lot
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
      • jshhh
        Help replacing fuse on my Mimaki CJV300-160 vinyl printer
        by jshhh
        Hi guys,
        I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
        How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
        Anybody know how to remove this type of fuse?
        (The fuse is toward the bottom of the image labeled F2)...
        06-17-2025, 01:35 AM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
