I've got an RTX 2070 here that doesn't artifact, no memory errors in MATS
  • A_LARGE_BEAVER
    • Dec 2021
    • Japan
    Originally posted by Joe24
    Thanks for that. This file seems a bit mangled, though. Several duplicated/missing pages (2x page 11 instead of page 10, etc.), and that is NOT the correct pinout for a uP9512.
    I've got an RTX 2070 here that doesn't artifact, no memory errors in MATS, boots fine in Windows Safe Mode, but freezes the instant you try to load a driver. BIOS manually reflashed, no change. Voltages are all fine, PCIe lines all look good. Suspect Vcore power supply issues, or I guess could be a bad GPU. My first 2070, so there may be potential causes that I'm not aware of. Not super familiar with the circuit.
    Joe24, I'm also dealing with a 2070 Super.
    My problems are:
    1. Blower fan spins at 100% and no fan data reported in HWINFO64. Also, fan control is grayed out in Nvidia Inspector. All attempts to control the fan are for not.
    2. GPU power draw is not reporting in any software.
    Card appears to work and even mines ETH pretty well. (my test)
    I've run the card in two different PCs, mobos, PSUs, Nvidia Drivers and reflashed the BIOS.
    Maybe, the BIOS sends the fan into 100 fan spin as a safe mode because it doesn't know how much power it is drawing? But, the temp sensors work(GPU and Mem temps).
    But, I don't know. Visual inspection of the card doesn't show anything unusual. The card is actually quite clean. uP9512 is bad?
  • badcapsdroid
    • May 2021
    • 6
    • paris
    Re: I've got an RTX 2070 here that doesn't artifact, no memory errors in MATS
    I have the same problem with Rtx Zotac 2070, sometimes it blocks or slows down the boot of the pc, but right now the Normal pc boot no artifacts, no errors under Mats, in games or under load with ETH mining it crashes.
    I have to downclock the memory by around 150 Mhz so as not to more Crash.
    I don't have a solution either.
    if i find any information i will post it here, please do the same.
    Thanks you.
    • chappers
      Nvidia MATS help please - 33 errors on two cards?
      by chappers
      I'm new to MATS and can only use it after watching a Youtube video, downloading the one he linked to (version 400.184) and running it without changing anything. I have no great understanding of it.
      I have 3 graphics cards in the house.
      My son's - Palit GTX 1080 used for 3D games constantly.
      Mine - Nvidia GTX 1080 not used for 3D games, just basic stuff.
      Inno3D RTX 2080 I bought faulty hoping to repair for my son's PC.
      Running MATS on my son's GTX 1080 gives a pass with no errors.
      Running MATS on my GTX 1080 gives...
      08-09-2023, 01:28 PM
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • konter
      ACER Nitro 5 AN515-55-774Z errors in mats
      by konter
      ACER Nitro 5 AN515-55-774Z ((FH52M LA-J891P REV.1))
      Intel Core i7-10750H
      RTX 2060 6GB GDDR6
      There was a short circuit on the video memory power supply. Replaced all memory with new memory. The short circuit is gone.
      Now the laptop turns on and works. But heats up a lot. Turned on with external cooling. In Windows the video card is detected but after installing the correct drivers it gives error 43.
      In MATS test on 5mb writes a lot of errors on all memory channels on the record. (Attached report)
      When testing on 2mb of memory built into gpu...
      10-19-2024, 11:24 AM
      NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
      The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
      10-02-2024, 07:51 AM
    • ktmmotocross
      Nvidia rtx 2060 - MATS shows no errors, but with OCCT Vram test GPU freeze with atefa
      by ktmmotocross
      Nvidia rtx 2060 - MATS shows no errors, but with OCCT Vram test GPU freeze with atefacts
      on this card i replace one VRAM chip and card work for 5 days, but now i know some other ram is bad. but how to find bad chip when MATS cannot locate it?
      10-31-2021, 03:18 AM
