Compaq EVO D510 - D51U Ultra-Slim Desktop
  • retiredcaps
    • Apr 2010
    • 9271
    I purchased an used Compaq EVO D510U (Ultra-Slim Desktop) and while it boots (I can't do any more testing because I don't have an USB keyboard and can't get past POST), I noticed 3 leaking capacitors and 1 bulged one. These desktop is very compact and may not have very good cooling?
    Obviously, I want to replace these 4 Nichicon 2200uF 6.3v, 10mm diameter, 20mm height, series HM(M), 105C. See pics.
    There are 7 Nichicon 2200uF 6.3v similar ones that look good with flat tops. It seems that the sentiment (but not consensus) from some on this forum is to replace them all regardless because if one fails, they *might/will* all fail, but since my soldering skills are a "D-" right now, I'm a little bit hesitant on a board this small with a lot of SMT chips next to the capacitors.
    Opinions on "don't fix it if ain't broke"? From skimming this forum, Nichicon seems to be a good name?
    I'm looking to replace them with either the
    a) Rubycon MCZ 2200uF 6.3v 10mm diameter, 20mm height, 105C
    Rubycon part number: 6.3MCZ2200M10X20
    OR
    b) Rubycon MCZ 2200uF 10v 10mm diameter, 25mm height, 105C
    Rubycon Part number: 10MCZ2200M10X25
    My reason for choice b) is that I could potentially use this capacitor for future fixes in other devices as it has a higher voltage rating. I have read that as long as the uF is the same, you can go a bit higher on the voltage.
    Do you think I should stick with the 6.3v or go with the 10v? I may need just one 20mm height for a tight fit, but 25mm is will work for the other locations.
    --- begin sig file ---
    --- end sig file ---
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Compaq EVO D510 - D51U Ultra-Slim Desktop
    Hmm, found this
    https://www.badcaps.net/forum/showpo...53&postcount=4
    and noticed that the Nichicon caps on this compaq have H0242 for date codes for 4 bad capacitors. The 7 "good" ones, but not tested, are H0243.
    So it looks like I should replace them all based on the manufacture date.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      yes why not
      i dont see the point to go for the 10v but there is no problem if you do
      practice makes perfect.
      • c_hegge
        • Sep 2009
        • 5219
        Remember, 10v and 6.3v caps can be substituted for each other. The highest voltage a 10v cap can be on is 5v as the next voltage up is 12v. it is OK to use a 6.3v cap on the 5v rails.
        • delaware74b
          • Apr 2009
          • 628
          I recapped one of these boards last month. I ordered in multiples of 10 for each of the sizes from digikey:
          10 ea Pan FC 1000/25 P11223-ND
          10 ea Pan FM 1000/10 P12353-ND
          10 ea Pan FM 680/16 P12377-ND
          20 ea Pan FM 2200/6.3 P12344-ND
          I replaced all caps 470uf and higher. It had popped all the VRM caps next to the CPU in the SFF version of this board. Total cost: $24 plus shipping. Main complaint: USB ports kept shutting down.
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
          • retiredcaps
            • Apr 2010
            • 9271
            Okay, delaware74b, this is embarassing. I can't figure out how to remove the motherboard. How did you do it?
            I included 2 pics. I took everything out of the machine and need to change those 4 caps circled in red.
            There are 4 solid steel/aluminum standoffs circled in yellow. The problem is that I cannot move the board sideways. I have tried pushing the board sideways, but those steel brushed standoffs have a very tight grip on the motherboard.
            I also cannot remove the power supply because the motherboard is blocking it. I can't life the power supply out because the "sides" and back are solid steel and not movable so the power supply is "trapped" in there.
            PS. I have always like Compaq's high standard of PC build in the past and this PC clearly shows it.
            • retiredcaps
              • Apr 2010
              • 9271
              And the secret I discovered today is:
              remove the heatsink and CPU.
              There are 2 screws holding down the motherboard (hidden by the heatsink). Once those are moved, the board slides out nicely.
              Got them recapped, but one cap lead broke in the desolder process - the other 7 leads were removed cleanly. Arrrgggh.
              I managed to work around it, but no amount of fresh solder, safety pin, etc would get it out. I didn't go any further since I didn't want to dislodge the solder pad from the board.
              PS. The power supply was full of Rubycon and United Chemicon caps. I didn't take a picture as the power supply is pretty small and crowded in these small form factors.
              Luckily none of the caps were bloated in the power supply otherwise that would be a nightmare to remove and solder.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Change all Nichicon HM/HN caps with bad date codes. Otherwise you might be doing this again in the near future.
                • bluto
                  • Oct 2007
                  • 560
                  I just picked up a Compaq Evo D513S over the weekend at the off lease computer store. I took the lid off to clean out the dust bunnies and lo and behold there were a dozen bad caps next to the CPU. All of the bad ones were Nichicon HM(M), date code H0306. Par for the course on those Nicicon's from the plague era. Its a good thing the store has a liberal return policy, because I'll be taking this one back!
                    HP Compaq Compaq 15-s006tu Notebook 15 Specification for Upgrade or Repair
                    This specification for the HP Compaq Compaq 15-s006tu Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Compaq 15-s006tu boardview and Compaq 15-s006tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    09-06-2024, 05:27 AM
                    HP Slim Desktop S01-af1132a Slim Desktop i3-10100 Specification for Upgrade or Repair
                    This specification for the HP Slim Desktop S01-af1132a can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-af1132a boardview and Slim Desktop S01-af1132a schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-12-2024, 03:28 PM
                    HP Slim Desktop S01-aF0010ns Slim Desktop J4005 Specification for Upgrade or Repair
                    This specification for the HP Slim Desktop S01-aF0010ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0010ns boardview and Slim Desktop S01-aF0010ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    HP Slim Desktop S01-aF0017ns Slim Desktop S01 3250U Specification for Upgrade or Repair
                    This specification for the HP Slim Desktop S01-aF0017ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0017ns boardview and Slim Desktop S01-aF0017ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    HP Slim Desktop S01-aF0005na Slim Desktop S01 J5005 Specification for Upgrade or Repair
                    This specification for the HP Slim Desktop S01-aF0005na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0005na boardview and Slim Desktop S01-aF0005na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
